timeing problem
Old Jul 22, 2004 | 08:09 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
timeing problem
Hello all..
Have a 89 350 TPI with a timeing issue......I have set my timeing to 5 deg advanced and the car idles great......"snap throttle is kinda lame(@ throttle body lever)...so i pulled the trigger on my timeing light while opening the throttle up slowly to about 3,000 rpm's..the motor rise's up..timeing too....but slowly...then the ECM seams to retard the timeing right away while I still have the throttle opened.No caughing or popping...the motor just starts to lay down.Now this of course does not work on the road,the car just lays down....just like a lack of fuel psi would ....BUT I have plenty there.I set it to 45psi..with the vac disconnected and plugged....plug it back in and she runs @ 43.5 all day long.I guess I 'm asking "What" is causeing the timeing to retard..rather than advance like it should when throttle is applied???? It has a 350 knock sensor in it..any idea's???? trying to save diag time by asking you all.hope I'm giveing enough info..just ask away if you need more.
thanks for your time
Brent
Old Jul 23, 2004 | 04:33 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
um..help???
um..is the answer that easy that i can't see it????.....I'm not trying to be impatient,but just wondering if my problem is a easy fix. I seem to be on my own on this one so far......can someone help me out??? or should I just go out and get a new knock sensor.
hope to talk to you all soon
Brent
Old Jul 24, 2004 | 08:50 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You may want to post up on the TPI board, someone there may have dealt with this issue before.
Old Jul 24, 2004 | 09:50 AM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
thanks
hey...great!..thanks for getting back to me..i will do that..now i know why they don't answer...doh:
Old Jul 24, 2004 | 12:40 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I responded in your other post in TPI.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
