did they change the size of the block plug for knock sen about 84?
Old 04-19-2001, 08:31 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
A friend is putting a 350 in a truck that had a 305. The truck is a 85 i think and when they went to put in the 305 KS it was too big. The 350 is a pre 85 with 2 piece oil seal. I was not aware they changed those. Can he get a KS for a 350 pre 84?(i thought they did not go with computer controled spark much earlier than that).
Old 04-19-2001, 09:05 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Ive used a 90-91 knock sensor in a 1971 block. So I know the later ones will work in the older blocks. Unless they used a larger sensor in 85 it should work. They are kinda tricky to start the treads.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old 04-19-2001, 09:07 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
As far as I know, they are all the same size.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old 04-19-2001, 09:47 PM
ede
ede's Avatar
all are 1/4" NPT, the senser just uses a hole made for the block drain plugs.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old 04-19-2001, 10:18 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
thanks for replies. Thats what I thought. I was not up under there but it looks like i will have to find out WTF myself.
i mean the general did some Fupd things but I did not think it was that bad. maybe I get to work on my car once I get this truck out of my hair.
Old 04-20-2001, 11:53 AM
383GTABoy's Avatar
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
I had that same problem when i was instaling my new 383 it was out of an old camaro 4 bolt 2 piece. I had to get a tap and lots of wd 40 to get it in but the hole seems the right size but I think that the thread is wrong.
Old 04-20-2001, 12:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. They are all ¼" pipe. However, the factory used steel plugs, and the whole arrangement has a tendency to rust together severely, so even after the plug is removed, the threads are often too small or damaged or almost non-existent.
Just get a tap and clean up the hole, it should then fit fine.
ICON Motorsports
Old 04-20-2001, 01:52 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
i still did not climb under there but, he said he had to get two adapters or bushings to make it fit. The ks is supposely bigger slightly. The engine rebuilder said 85s did not have KS (well, even if they didn't they had water drain plugs). I was going to look and see what size bushings he had to use. I am not sure the KS will work right with all of that stuff between the block and it.
Old 04-20-2001, 02:56 PM
Biochem's Avatar
Car: 2002 SOM z28
I am 99% sure my 1984 305 didn't even have a knock sensor... I think only the HO version did, but not the LG4. That is why I was pulling a code when I put in a Hypercrap chip... no knock sensor.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old 04-20-2001, 06:08 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Yup, Biochem, only the '87 LG4 got the KS. Otherwise only the L69s had the KS for E4ME engines.
George P. Lara
1984 357 T5
1994 LT1 M6
SCCA, SCFB, SC3GFB
Infested
05-22-2018 11:56 PM
toronto formula
11-10-2015 06:17 AM
db057
08-22-2015 08:17 PM
knight72
08-10-2015 09:32 PM
Quick Reply: did they change the size of the block plug for knock sen about 84?
