Mounting provision on frame for a torque restraint?
Old Apr 19, 2001 | 11:11 PM
Jester's Avatar
I wanna use a torque restraint on my new engine to prevent excessive engine movment. I'll prolly just use a chain...altho I may get fancy and use spherical rod ends later. My question is about how I should mount it to the frame. Should I drill a hole vertically through the frame and just run a bolt through it? should I weld a plate to the top of the frame? What would you do?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Apr 20, 2001 | 07:54 AM
ede's Avatar
ede
use 2 rod ends in a solid rod. bolt one to the head and the other to 2 angle clips welded to the frame. you'd want the bolts to be in a double shear application if you can. you might want to get someone with a mig machine to weld the clips for you, or use self tapping bolts.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 20, 2001 | 09:03 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
I am using a generic turn buckle from the hardware store. I tried an aluminum one first and bent it, So Went and got a steel one and it is living just fine. All I did is just drilled a hole straight through the frame, and then bolted the turn buckle to the head. I have absolutely no twist from the motor. Also My reaction times dropped considerably, by well over a tenth. My reaction times now are mid 500's to low 600's. I think its a good investment.
John
82 Firebird,408,Dart Iron Eagle 215's,Cam 229/239, .498/.520,TH350 Tranny, 750 Speed Demon carb, Hooker Headers(I.E. POS) Manual steering, Also a cowl for the big hole in the hood.
Shooting for low 12's.
Check out my birds new home.
Old Apr 20, 2001 | 01:56 PM
Jester's Avatar
Hey spud..have you noticed any distortion in the frame rail from the twisting?
JSP Motorsports
ICON Motorsports
Old Apr 20, 2001 | 04:37 PM
spud's Avatar
Engine: 400 & 355
No
I drilled all the way through about 6 inches behind the steering box. I got lucky my car has a rasied spot in the lower frame there so a 6in bolt will run through the entire frame. With this configuration my motor will not move in the slightest. Its sad to say i stole the turnbuckle idea from a mustang friend. (but it works thats all that matters to me)
Later
John
Old Apr 20, 2001 | 05:23 PM
Jester's Avatar
Thanks spud..sounds pretty good to me. If I elongate the hole too much over time I can always weld it then.
Old Apr 20, 2001 | 07:47 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I saw a T-type at the track once where he had tied his engine to a large (1/4 in diameter or so) eyebolt run through a frame member. Eyebolt wasn't tough enough though. Just as he was showing off his handiwork at the track someone noticed that the eyebolt was bent.
I always figured the real "Jester-ish" thing to do would be using a large rusty logging chain run up and over the intake.
Old Apr 20, 2001 | 08:13 PM
Jester's Avatar
Well D you'd be amazed ar how hard it is to find large rusty loggin chains in Miami
JSP Motorsports
ICON Motorsports
Old Apr 20, 2001 | 10:42 PM
87RS402's Avatar
I've got one I can send you.
Old Apr 21, 2001 | 07:27 AM
ede's Avatar
ede
yeah jester i have a few old rusty logging chains laying around here i could send you to help out the cause.
ICON Motorsports
1st & 3rd
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
