Massive detonation and low oil pressure
Old Apr 20, 2001 | 03:16 PM
theformula's Avatar
Just for starters I have a disabled knock sensor and the car was performing very well the first day it was gone.
Well NOW the car is detonating for sure. Mostly when I'm in boost. I noticed my oil pressure is alot lower than usual too.(could be sending unit still original one).
Heres my question. If low oil pressure is causing detonation, will the knock sensor take care of it?
I'm scared I'll just be hiding the "low oil pressure" problem when I put the knock sensor back in. Any thoughts or suggestions? What would cause the low oil pressure?
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Apr 21, 2001 | 07:38 AM
ede's Avatar
ede
i think you'll get more help on the power adder board so i'll move this there.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
