After installing headers/exhaust...I got some pretty strange problems
Old Apr 21, 2001 | 10:43 AM
RoadRocket L98's Avatar
I recently finished my header and exhaust install and like everyone, expected a gain from it. What I got was three strange problems that have me puzzled.
A. When you punch it at low speeds, the car hesitates bad, then picks up after a while.
B. Sometimes the car backfires when I let off the gas.
C. The car is slower. I spent $700 and about a week on installation and the car is slower.
Anything you guys can to do help is appreciated. Thanks.
'83 Firebird 2.8
'89 Firebird Formula 350
Red/grey, t-tops, and a 3.27:1 rear
K&N, TB bypass, no MAF screens, CAI, full Accel ignition, no cats, Hooker Supercomp shorties, Hooker 3-inch catback
Old Apr 21, 2001 | 12:25 PM
ede's Avatar
ede
have you had it at a track to tell it's slower? if so it may be the weather conditions. is the o2 senser hooked up? have you changed the timing? you might want to make a small adjustment there. didn't unhook a line or wire while you were doing the swap to headers?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 21, 2001 | 12:39 PM
bomax's Avatar
I have SLP headers, a hollow cat, and a flowmaster cat-back system. I have the same problems you're having, and it's cause I got an exhaust leak!! Are you also running rich? Listen for a clicking noise, since that's a sure-fire tip off of an exhaust leak near the headers. Go under there and tighten up all the bolts you can. Should fix it right up...
Old Apr 21, 2001 | 12:45 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Sounds like what happened to my one friend who owned an '87 GTA. Did a full 3" exhaust on it with SLP headers, and eliminated the cat. Result? Back-pressure got too LOW. Car dogged out at low rpms, acceleration was sloppy until about 2,500rpms and then it picked up.
I don't know if you eliminated the cat or not, but low back pressure is sometimes not a good thing. Also like ede said make sure your O2 sensor is still present/functioning, and you may want to advance the timing by a degree or two. My L69 ran like a slug with my 3" exhaust until I advanced base timing to 4*, now it's all better.
DR Stevens
1984 Trans Am 305HO L69
sucks gas, hauls ***
1991 Firebird 305 LO3
for days when I need a/c
Old Apr 21, 2001 | 01:32 PM
Thanks guys!
'83 Firebird 2.8
Old Apr 21, 2001 | 02:59 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
had SAME problem 6 and 8 wires were crossed.
Old Apr 21, 2001 | 03:15 PM
BlueZ89's Avatar
Yeah, recheck the firing order and be sure no plugwires are shorted on the header tubes..........
Infested
May 22, 2018 11:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
TheJoeY88
Aug 13, 2015 06:51 PM
