Car Doesn't Shift Right!!!!
Old Apr 21, 2001 | 09:07 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I have a really bad exhaust leak, almost sounds like open headers, and now my transmission isn't shifting when it should, when I step into it and go to shift into OD, it just stays at high RPM and then it will shift. I was wondering if this can be related to the exhuast leak, I know the TV cable controls shifts and I have never adjusted it, but it was ok before the exhuast leak but now the car doesn't want to shift right.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Apr 21, 2001 | 09:16 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Try adjusting the TV cable 1st, its not hard to do at all.
Old Apr 21, 2001 | 10:05 PM
Car: 99 Formula
Axle/Gears: 342
It shouldn't be that though, it just started around the same time the exhuast leak got worse, I have to pass my car thru emissions and it has failed 2 times already, I was hoping to wait and get the leak fixed after the test that way hopefully most of my exhuast doesn't even reach the tailpipes.
By the way I read the tech article on adjusting the tv cable, I'm an idiot when it comes to working on cars and couldn't do it, is it the cable that is attached to the throttle.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
maroe624
Apr 16, 2017 08:29 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
killer777
Aug 8, 2015 02:47 PM
