Whats the correct way to install valve seals?
Old Jul 27, 2004 | 04:34 PM
StealthElephant's Avatar
Car: 87' Iroc
Well they leaked the first time I installed them. I used a rubber mallet to coax them all the way on and I probably messed some of them up.
Is there a better way to put them on?
Old Jul 27, 2004 | 04:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What type of seals are you installing?
Old Jul 27, 2004 | 04:52 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, I just finished installing valve guide seals today on a set of "993's" but like five7kid said what kind of seals are you installing???
Auggie
Old Jul 27, 2004 | 05:21 PM
Car: 87' Iroc
Here ya go:
Old Jul 27, 2004 | 06:29 PM
ede's Avatar
ede
there is a " special tool" that looks like a plastic sleeve to prevent damage to the seal goes on the valve tip andthe seal slides on. helps to use a little oil and maybe push the seal with a socket
Old Jul 27, 2004 | 07:14 PM
Car: 87' Iroc
Any more info on the tool?
Old Jul 28, 2004 | 04:20 AM
ede's Avatar
ede
it comes with seals or gasket sets. i just changed tool boxes and must of threw a dozen away.
Old Jul 28, 2004 | 06:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I always take some 600 grit sandpaper and make a quick pass around the valve stem tip and the keeper groove, to eliminate any burrs or sharp edges that might damage the sealing surface to the stem; and use a socket to push them on.... gently and carefully.
I don't generally use the little sleeve tool.
I find it easier to put the valves in first, then put the seals on.
Old Jul 28, 2004 | 10:31 AM
Auggie's Avatar
Well, them seals look like the seals off of a set of Vortex heads?
I just installed a set of Sealed Power seals (XUA-MV1888) on a set of "993" heads and they came with a clear plastic sleeve. These seals are for a .562" guide and a .343" (11/32) valve stem. This clear plastic sleeve "must" be installed over the valve stem to prevent the seal from being damaged when it is pushed on to the valve guide. I lube all moving parts with #80w gear oil including the seal. I use a 3/8" drive 7/16 deep well socket to install the seals. I do not use valve stem o-rings or valve spring shields because of the positive seal that these type of seals provide I use the same seal on both the int. and exh.
Auggie
Old Jul 28, 2004 | 10:54 AM
Auggie's Avatar
Here's a pic.
Auggie
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
gta90
Sep 15, 2015 04:00 PM
lakeffect2
Aug 23, 2015 08:44 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
