ABS, anybody install a system in our cars?
Car: 91 Red Sled
Has anybody installed an ABS brake system into their car and if so, what parts and how hard was it?
, Jon (350 TBI! it's trenuous and efficacious while getting 23mpg highway with off the shelf eprom)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
Car: 82 camaro SC
I've never heard of it. My question is: Why? If you know how to use the brakes, ABS has no or little advantage. My other two vehicles have ABS and I prefer the non-ABS.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
I have no real experience with ABS systems, but I'll give it a shot, first, you'll need to find rotors with the ABS triggers (I guess that's the correct word..) second, you'll need drums, which could easily be gotten from a 4thgen. Third, you'll need the sensors, and then the ABS computer. Fourth, you'll need whatever kind of brake master cyl and or prop valve that ABS systems use.
I suggest borrowing a 4thgen service manual from the library and copying the ABS wiring diagram, it doesn't sound like it's incredibly complicated.
I belive finding stock-style rotors would be the hardest part
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Macgyver:
I belive finding stock-style rotors would be the hardest part</font>
As for putting in ABS, I dunno. Someone did it, see if a search yields something, here or the net. Pretty sure I saw something before.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
What do you mean "know how to use the brakes"? Is there a trick to braking our cars in different situations? I usually just press the pedal, lol. But, if there is more, please tell, cause I'd really like to learn.
Not a "trick" specific to any particular model of car, the threshold technique he was refering to for panic stops (the only time the ABS is needed) keeps the maximum braking force possible applied without locking the wheels. As I'm sure you're aware, when the wheels lock, you have no control over the car (bad). When you learn to modulate the brake pedal to keep the wheels at the limit of adhesion without locking, you will see shorter stopping distances, and hopefully avoid ending up in the trunk of the car in front of you!
'87 IROC Z28
TPI 305
5-speed w/ Centerforce clutch
3 1/2" exhaust w/ Flowmaster
Clarion, Kenwood, Eclipse, Polk, MTX, Autotek 800 watt stereo system
Grant wheel
Otherwise stock, & good for a 14.68 at DeSoto Dragstrip
More to come soon...
Shooting for high 13's with bolt-on's
'87 IROC Z28
TPI 305
Grant wheel
colton_carlson
Mar 8, 2019 12:21 PM
9192camaro
16
Feb 3, 2019 12:21 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
