How hot can our cars get with out blowing head gaskets?
Old Apr 22, 2001 | 08:38 AM
LottaBallsCamaro's Avatar
Same as above
We are the future, the 21st. century dislexyic, glue sniffing, cyber *****, with homicidal minds and handguns.
Old Apr 22, 2001 | 09:00 AM
ede's Avatar
ede
first thing i thought of is why you'd want to know? like most car related things ther isn't a set answer, but i'd not let mine run over the 240* range. i know you'll find people who will say they've went 300* with no problems nd others that blew head gaskets at 200*.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 22, 2001 | 11:06 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I let mine go to who knows where past 300 and nothing happened. But i wasn't watching the temp gauge so i don't know how long it was at 300+. Surely after i saw it i did go park the car and try to see what was wrong. Never goes past 220 now i feel alot better with that kinda insurance.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Apr 23, 2001 | 02:44 AM
burnoutrpm's Avatar
ok ok ok let me get this strait....you ACTALLY LET your car go to 300* just to see if it would hurt anything?? what the **** are you thinking?? ...bored anyone??? i wont let mine run over 200* thats the absolute limit for me!!well... i havent run it since the new re-build its going to be 60 over now this will be FUN to cool!!!
89 firebird formula
360 11.0:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1407edlebrock 750
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
[This message has been edited by burnoutrpm (edited April 23, 2001).]
Old Apr 23, 2001 | 07:24 AM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
burnout- read the whole message, I don't think that was intent.
I've had mine to 250+ plenty of times because of cooling problems. I haven't yet blown a head gasket(thank god). Since I installed the dual fans I have no worries now.
92 RS, 350, Street & Performance MPFI, TFS heads,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Old Apr 23, 2001 | 08:14 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
jeez i never run mine that hot. It stays at about 185 most of the time, but in the summer if I try and use my A/C it will climb past 220, and I gotta shut off the A/C. I had to install a heater control valve just to keep the temp stable in the summer.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
Old Apr 23, 2001 | 08:39 AM
I ask because if I'm sitting at a light or in stop and go traffic, it will get hot real fast. I usually turn the car off if I know I'll be sitting for a while. I plan on rebuilding the engine in about another 25,000 miles, but I wanted to make sure that my head gasket will survive til then.
With this car, it's never a question of "can I...", only "will I..."!
Old Apr 23, 2001 | 09:54 AM
87 Trans Am TPI's Avatar
I think that you need to pay attention more to your constant heat. My car always runs around 175, with a 180 degree thermostat and a manual fan switch I use w/ the A/C and in slow traffic, I had a collant hose blow and the temp reached 270, nothing happened. I think cuz then engine has been in good health at running cool temperatures all the time. If your car is always around 220-25o BEWARE!, if it gets much hotter it ain't gonna make it! wire up a manual fan switch, and/or drill to small holes in the rim of your thermostat, thats helped me run cool at all times.
1987 Trans Am
5.0L TPI
Automatic, all pwr. op
Digital Dash
Flowmaster Muffler
gutted cat
removed MAF screens
TransGo Shift Kit
Old Apr 23, 2001 | 10:19 AM
raging86's Avatar
i don't think small block chevys really ever have head gaskets blow. how often have you seen a blown head gasket on a stock or properly build SBC? i don't think i have ever seen a blown head gasket. i'm sure it can happen, but on REAL engines that rarely happens. now those buzzing turd ricers, they blow headgaskets all the time when they get hot.
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
MY87LT
Aug 17, 2015 08:43 AM
