oil filter ? (not the usual)
Old Jul 30, 2004 | 04:21 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
I went to autozone today to get the stuff to change my oil.
I usualy only use Mobil 1 for both.
when looking for the filter M1-202 I couldnt find it or the tag on the shelf for it.
I went up to the counter and asked about it so the guy looked it up and gave me the new number for it. I go back pick it up and this filter is only half the size it should be(its shorter).
Needless to say I didnt get it and decided to give K&N a second try.
maybe one of you all could shed some light on why Mobil would change the size of the filter for SBC engines. I always hear about people using slightly bigger(taller) filters not smaller.
It makes no sence to me as the M1-202 filter was popular and many times autozone would run out of stock.
Old Jul 30, 2004 | 04:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably because it isn't economical for them to produce and stock half a dozen nearly identical filters that only vary by length.
Old Jul 30, 2004 | 04:48 PM
Car: 91 Camaro RS
Engine: 305 LO3
That I understand, but the M1-202 and its now replacemt are the only Mobil filters my Autozone list to fit the SBC.
Old Jul 30, 2004 | 05:39 PM
Car: 91 Camaro RS
Engine: 305 LO3
sorry for the double post of the same topic, my daughter came in right after I posted and must have done some thing.
mods please remove one of the post's.
Old Jul 30, 2004 | 11:53 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Did you check in the truck section too? They gennerally used a larger filter.
Old Jul 31, 2004 | 12:00 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yup, I always buy truck filters for mine... a '79 4x4 Suburban 350 to be specific... they are BIG filters compared to stock Camaro stuff.
Old Jul 31, 2004 | 12:24 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Wel lat least you are staying away from the "orange cans of death" filters Try an M1-302 mobil one filter. This is the standard length filter.
Or you can get a 15 micron filter in a 2 quart version from amsoil for around $10.50 each. Amsoil is the only manufacturer I know of to make a 15 micron filter in the 2 quart version. It has over double the filtering area of a standard filter, and adds almost a full extra quart of extra oil capacity.
If you are interested in learning more about oil and filters go here. And be sure to read up about German Castrol.
http://theoildrop.server101.com/ubb/ultimatebb.php
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
