replacement motor
Old Aug 1, 2004 | 01:37 PM
blowntransam's Avatar
replacement motor
I have a 86 trans am with a 305/tpi and a 700-r4 tranny.i have searched all over this site and the internet to try to find a replacement motor,longblock,shortblock or anything for the 305.Does anyone know where i could get a rebuild kit.i saw one on summitracing.com but ih had 8.5 to 1 compression ratio i thought this was to low and would mess up the computer.Any help would be appriciated.
Old Aug 1, 2004 | 01:41 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
www.northernautoparts.com
www.gmpartsdirect.com
www.gmgoodwrench.com
www.paceparts.com
www.spc2000.com
But why!?
Old Aug 1, 2004 | 05:40 PM
Vader's Avatar
In your seach for either a complete engine or short block, consider changing to a 350. They are a lot more available, will provide equal highway fuel mileage, only 1/2-1 MPG lower city mileage, and a lot more power and aftermarket parts availability. They are likely going to be cheaper, too.
The only other differences you will need to accomodate will be a different ECM PROM and the larger, 22lb/hr injectors. Of course, there are a lot of sources for the injectors, and either a factory '87 L-98 (350) PROM or custom burned PROM can be had for your potential 350 setup for well under $100. The factory calibrators (PROMs) are around $60. I'm thinking that there are several people on this board that can burn a custom PROM with factory 350 parameters for almost nothing. The L-98 binary code files are all over the 'net for free, and a PROM itself is about a $10 item.
TheExaminer
Aug 26, 2015 04:59 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
mdtoren
Aug 16, 2015 05:45 PM
Leggman1
Aug 6, 2015 04:15 AM
NBrehm
Aug 5, 2015 07:57 PM
