valve cover gasket
Old Apr 23, 2001 | 11:06 AM
lordlexus's Avatar
valve cover gasket
Hey guys. I have to pull off the valve covers to adjust for the 'ticking' noise from the engine. Do I have to replace the valve cover gaskets, or if I'm careful (and lucky), can I reuse the old ones? Also I'm putting on an open element (K&N) and I'm wondering if there might be any overheating issues with the engine not getting any outside 'cool' air. Any help would be great. Thanks!
(Virgin) 92 Camaro RS Anniversary Ed.
Old Apr 23, 2001 | 12:08 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I haven't put on an open element setup but you shouldn't have any problems with the car overheating. One thing to do to help get some cooler air in is to remove the gasket from the rear of the hood. Thats a high pressure area and you'll get a lot of cool air into the car.
The valve cover gaskets, depending on the type of material should be reusable. You might want to grab a spare set anyways just in case. After you put the valve covers back on just check for leaking. If it is leaking then change them out. Its not like getting to the valve covers is difficult anyways.
mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job.
Old Apr 23, 2001 | 12:11 PM
lordlexus's Avatar
<font face="Verdana, Arial" size="2">Originally posted by burntblues:
mike
</font>
Thanks Mike!
Old Apr 23, 2001 | 03:08 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
hey lordlexus,
your best bet is to go down to a parts store and get a set of the Fel-Pro rubber valvecover gaskets. they're better than the stockers, and will be able to be re-used after a thorough cleaning each time the valve-covers are removed.
on my website I have an open-element aircleaner tech article, check it out if you're curious how one of my users did it. here's the link: http://www.iroc-z.org/tech/carburetor/openelement
i'm originally from Red Deer, damn I miss that place..
if you'd like to chat more, email me at admin@IROC-Z.org
ttyl!
Colin
Webmaster: www.IROC-Z.org
Old Apr 23, 2001 | 04:21 PM
lordlexus's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ColinOpseth:
hey lordlexus,
ttyl!
Colin
</font>
lol. You MISS Red Deer? You gotta be crazy! Hey thanks for the article very helpful. I tried doing the element yesterday but I got a little greedy on size and couldn't close my hood...Once I get a replacement it'll be great to check out the difference. Then a driveshaft...good thing I don't have to wear dentures. You can email me at lordlexus@hotmail.com. Later,
Jay
Old Apr 23, 2001 | 08:48 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Its not like getting to the valve covers is difficult anyways.</font>
Obviously you don't have TPI.... the passenger valve cover is a mother to get off because of all the emissions crapola....
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 23, 2001 | 11:32 PM
CrazyRob75's Avatar
One little trick is to silicone/glue the gaskets JUST to the valve cover. That way you can pull the covers WITH the gasket and not have to worry about them sticking to the head and tearing!
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
db057
Sep 4, 2015 07:57 AM
Victor6
Aug 30, 2015 02:09 AM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 8, 2015 01:18 AM
