head bolt?
Old Apr 23, 2001 | 03:14 PM
88rscaamaro's Avatar
head bolt?
i'am missing a head bolt could this cause water to get it to the oil? its the middle bottom one on the pass. side if it helps
1988 Camaro RS T-Tops white. Was 2.8 now a mean 406 sbc
(mods)
750 Edelbrock carb
Performer RPM intake
Comp cams Magnum @.50 230-230 lift 480-480
Flowtech 1 3/4 headders with glasspacks for true duals and thats it for now
E.T. 1/4=?
will post when race season starts
2 10' Kicker comps
Kicker 500w amp
Pioneer head unit
2 Jensen 3-way 6x9
along the road
perfomer RPM heads?
NOS
pistons, rods
roller rockers
4.10 rear with posi
91-92 ground effects
Old Apr 23, 2001 | 03:15 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
how are you missing one? did you lose it?
i would go to a parts yard and pick one up if I were you..
Webmaster: www.IROC-Z.org
Old Apr 23, 2001 | 03:17 PM
when i got the motor it was missing. but would it cause water to get into the oil?
Old Apr 23, 2001 | 03:56 PM
Engine: 305TPI
well, there's always a possibility that the bolt was in the area of a water jacket and would weaken the joint between the head and block enough to allow the head to warp up and blow the head gasket..
Old Apr 23, 2001 | 06:20 PM
ede's Avatar
ede
hell yes it would buy a head bolt and stick in it
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 23, 2001 | 11:36 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
SBC head bolts go into the water jackets.
As Ede said, get a bolt in there.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Apr 24, 2001 | 04:06 PM
thanks guys that was my prob. stuck one in there and it fixed it. thanks guys
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
