Little engine trouble
Old Aug 7, 2004 | 06:15 PM
qwik86z's Avatar
Was just running my engine for a bit. Gave it a half stomp on the pedal from idle, engine raced up fine, but stayed probably at 2500ish when I let off (no tach in car atm).
Checked the throttle linkage just incase, but it was fine. Car cranks really hard/slow, so I'm guessing the timing shot up too advanced? That would explain the increase in idle speed and hard to impossible starting, correct?
I just can't figure out how this would happen, distributor is tight. Running msd 6al, mechanical advance billet distributor, coil/wires and a holley 650 doublepumper. I don't have a timing light, so thats another problem right there.
Any ideas/suggestions?
Thanks,
Old Aug 8, 2004 | 07:59 AM
Vader's Avatar
Check the secondary throttle plate alignment and actuation linkage. Sticky secondaries can be tricky.
Old Aug 8, 2004 | 02:57 PM
qwik86z's Avatar
I don't think I would have thought to check that. That was the problem. Just opened it a little bit and when I closed it I could feel it catch something, little dirt or the like, and it closed fully. Started up and idled normal. Dunno why it was hard to turn over last night after I shut it down though.
Thanks for the help!
Old Aug 8, 2004 | 03:51 PM
Vader's Avatar
Figures. Goofy Hollies...
backtothe80s
Sep 5, 2015 12:39 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
