Converting to Serp from Vbelt, Questions W/in
Old Apr 26, 2001 | 05:21 PM
Bort62's Avatar
After Spinning off another Belt today, Im thinking I should Go ahead and Convert Over to a Serp Setup from a later 3rd gen.
What Im wondering, Is what All Do I need ?
My car has an electric Fan, Alt on the pass side, PS and water pump.
No Smog pump, No AC
So I would need PS, ALT, and wp pulleys, plus a tensioner, then whatever size belt, right ?
Thanks.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Apr 26, 2001 | 06:33 PM
John Boy's Avatar
I've done it. I got the kit from www.tacreationsusa.com It came with everything you need minus connectors. This may be the way to go if you don't have a junk yard nearby cause everythings different. I did a search but couldn't find the post where Willie tells all about it maybe you can find it.
Old Apr 27, 2001 | 08:36 AM
Mark W. Winning's Avatar
Tran AM Creations are a great bunch to deal with. I have bought a bunch of stuff from them. They are at http://www.tacreationsusa.com.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
[This message has been edited by Mark W. Winning (edited April 27, 2001).]
Old Apr 27, 2001 | 09:15 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
<font face="Verdana, Arial" size="2">Originally posted by John Boy:
I did a search but couldn't find the post where Willie tells all about it maybe you can find it.</font>
I couldn't find it either, so I'll try to outline everything again.
Obviously, you'll need the two main brackets, including the tensioner. Also, there is an alternator support bracket that attaches to the top and back of the alternator and the front exhaust manifold stud. On the passenger side, there are two support brackets; one mounts from the main bracket to the intake manifold and the second attaches from the main bracket back to the third exhaust manifold bolt (stud).
Required pulleys:
Air pump (with pulley spacer),
Power steering pump, &
Water pump.
Accessories:
Water pump (reverse flow impeller),
Alternator (different mounting hole location),
Air pump (possibly, depending on what you have now),
Air pump line (metal),
A/C compressor,
A/C compressor lines,
All the bolts used for the main brackets are the Torx bit style except for two studs. The alternator wiring will need to be extended. The A/C compressor wiring is routed from the rear of the engine on the left hand side. In order to have a "clean" installation, this wiring should be removed from the existing wiring loom and re-routed on the passenger side. Otherwise, you'll have wiring strewn across the front of the engine (ugly).
Chances are I've forgotten something but this information should get you going in the right direction.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
Current ATI D1SC (Initially 10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited April 27, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
