car stalling out while driving
Old Aug 11, 2004 | 11:55 PM
camzcruizer's Avatar
hey when i drive my car sometimes the check engine light will come on and the car will start to stall out and it will still continue to run like its out of gas then either ill pull over and shut it off or it will die then ill try to restart it and it will either start right back up or ill have to wait a minute or two and itwill run fine sometimes repeating the whole thing or it will be fine for a while WTF is this fuel pump, ignition, injectors, any one have this crazy problem cuz i need to get it fixed i use this car everyday
Old Aug 12, 2004 | 12:26 AM
drdroopy's Avatar
Car: 1991 Firebird
Engine: 3.1 V6
well my friend, i was having the same problem, untill it got worse, the last time that happened, i couldnt get it back on, i am currently still working on the problem, but if you want you can check out my post, mabey there is something in there that could help you
https://www.thirdgen.org/techbb2/sho...hreadid=249417
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
kyleb24
Aug 15, 2015 08:24 AM
TreDeClaw
Aug 14, 2015 06:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
