iroc problems
Old Aug 13, 2004 | 07:00 PM
nightprowler's Avatar
Car: 90 iroc convertible/90 firebird
Engine: 5.7
Transmission: 700 r4
iroc problems
Really would like to figure this one out guys. I got a 90 iroc, with a 305 tpi. I got a code 24 wich is the sps sensor. My tach doesn't work, which I think it's related too. But here lies the real problem. If I let my car sit for 2-3 days and go crank it, it kicks the check engine light on, and acts like it doesn't want to run right. I got new plugs, wires, valve guides and it should run pretty well. If I let it run for about10 minutes an cut if off and crank it, the light goes off, or if I disconnect the battery it goes off, and runs fine. Btw the code 24 is the only code I get, so is this causing the problem, or is it something else? If I crank it everyday, it does not do this. Would the throttle positionig sensor do this also? Thanks in advance.
Old Aug 14, 2004 | 12:23 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
If your speedo is working properly, the problem may be in the ECM or CalPac.
Open the ECM and reseat the CalPac.
Also check the tach signal from the dist before & after the filter.
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
