rough idle/ stalls cold engine
Old Aug 15, 2004 | 05:22 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
thought about this after i posted about the white smoke. when i start the engine it will stumble and cut off especially when i put it in gear. if i drive about a block it will run ok after that, have already cleaned the linkage on the carb and tuned up. what else should i try????
Old Aug 15, 2004 | 07:29 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
is the choke functional/adjuste properly? To me, this sounds like a choke issue.
Make sure the choke is getting proper voltage, make sure there are no gummed linkages, make sure its set correctly.
On a side note, you are pushing the gas before starting, correct?
Old Aug 16, 2004 | 07:57 AM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
yep sometimes if im in a hurry ill put the a/c on and that helps
sometimes
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
