Why did my 2001 T/A A4 go out in 3000 miles?S.H.I.T
Well guys.. the tranny in the 2001 t/a is gone.. it's a A4.. lasted 3014 miles..
Never would make the 2/3 shift at wot.. it would hit the rev limiter..
I lost OD,3, then 2nd... it's at the dealer now.. stuck with a grand prix until then..
Full of fluid, looked good, smelt good... any ideas? Maybe i should try do ditch the car altogether and get a M6
Shane Buss 92 Firebird 355, Holley 800 Double Pumper Carb, Vortec 1.94/1.50 Heads (Ported,Polished,Milled .025), 10:1 Comp Ratio, Cam Specs 224/234 498/520, 1.6 Roller Rockers, Hooker Headers, Flowmaster, !Cat, 3.73 Posi, Msd 6A Ignition Cyb. Speedo box, Single Plane Intake
http://users.ev1.net/~sdbuss/index.html
Note all girls on web page are x's, and will be removed when i get more time
WEIAND SUPERCHARGER REMOVED
2001 LS1 Trans AM A4. Bone Stock. 3.23 Rear End
Car: Take
Engine: Your
Transmission: Pick
Probably just a fluke from the factory. Last year we had a rash of Torrington bearing failures causing all sorts of funny things. It was the input thrust bearing to be more specific. I guess it was just a bad batch. Who knows.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
GMTech what is the standard procedure? Just a rebuild, or do they replace the whole tranny..
If they do a rebuild any chance of me bringing a shift kit up there?
Car dynoed at 291/310 ft-lbs
Car: Take
Engine: Your
Transmission: Pick
Depends on the damage. If it costs a few dollars cheaper to overhaul, it will be overhualed (got to save those $$$) If the damage is extensive, it will be replaced. I pulled one out of a Conversion Van w/ like 10,000 miles, that I could not even tear down. The internals got welded together, I could never find out what was wrong. Weird things happen, thats one of the perks of working at a dealer I guess.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
They are replacing.. They said they should have the new one in on monday and it will be ready monday night.. unless the freight truck comes late monday then it will be ready tuesday...
Who knows.. Shane
p.s.
tranny's need to be broken in at all or not?
Who knows.. Shane
p.s.
Car: 2006 Silverado 1500
Engine: 5.3L
no need for a break in on a trans. why did it break? sounds like it had a valve body concern from the start to me. but for a good reason at work we just figure if they build a few million a year, going to get a few bad one's. just sucks that you got one of them bad one's.
Car: 2002 SOM z28
You should have them install the Yank 3200 when they put in the new tranny
Then you will have a fast car!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Then you will have a fast car!------------------
<font face="Verdana, Arial" size="2">Originally posted by ShaneBuss:
</font>
</font>
Mike
1989 Turbo Trans-Am
11.25@121.25
Daily Driver
1998 Trans-Am LS1 6 Speed
13.10@106
Slow POS sitting in the Driveway awaiting repairs and then its For Sale. No More V8 Cars for me.
[This message has been edited by TTA (edited April 28, 2001).]
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
They need to start building these cars good again, they are having more BS with these 4thgens. Thirdgen's are better quality cars then they are.
got 63K on my '98... no probs like that at all.
<font face="Arial"><a href="http://www.geocities.com/battstas/cars/transams.html" target="_blank"><font size="2">Click here to see my Trans Ams</font></a>
<font size="1">1986 Trans Am WS6 (#40,977 of 48,870)- Silver, 305TPI, 16" charcoal gray cross-lace wheels. 168,500 miles, LB9, 700R4.</font></font>
<img src="http://www.fbody.com/members/98TransAm/86/1986.jpg" width="200" height="80">
<font face="Arial" size="2" color="#FF0000"><marquee width="201" height="18" scrollamount="3" bgcolor="#000000">CURRENTLY: the '86 was rear-ended in Austin (about 3K worth of damage), and is undergoing repairs. </marquee></font>
<font face="Arial" size="1"><a href="http://www.fbody.com/members/98TransAm/DSC00037a.jpg">'98 Trans Am</a>- (#907 of 12,046)- 3.23 4A, Chrome Wheels. 62,000 miles. <a href="http://www.fbody.com/members/98TransAm/DSC00055ga.jpg">'99 Honda VFR800fi</a>- 5,000 miles, GIVI wind screen <a href="http://www.fbody.com/members/98TransAm/99rodeo1.jpg">'99 Isuzu Rodeo</a>- V6 2WD 20,000 miles. </font>
My 3rdgen went 120k on the stock tranny with a powerfull motor.. after the blower it did let go though.. paid my friend $300 to rebuild it (including parts)... even the blower doesnt scare it ...
Shane
Shane
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
my 700R4 lasted 170K behind the L03 and not even 3 months behind the Vortec! Youre getting a new trans anyway so I wouldnt worry about it too much.
PS- my uncles 98 6-speed had to get the trans replaced after 11K miles....so I dont see one trans having the advantage.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
blackandblue02
Sep 10, 2015 08:19 PM
