fan relay location. where the f*#K is it ?
Old Aug 17, 2004 | 08:49 PM
stangStomper83's Avatar
Car: 89 formula and my late 86 iroc R.I.P girl
Engine: 89 firebird formula-305 tbi,86 iroc 305 tpi
Transmission: both 700r4
just swapped a tpi 305 from an 86 z28 into my 89 formula. i had the wiring harness converted for the tpi and i connected the fan and there is a connection for the relay, but i cant find the relay. do any of you guys know. ( a few people told me it was in the fender but its not there.
Old Aug 17, 2004 | 11:34 PM
MdFormula350's Avatar
on the drviers side firewall, right next to the brake booster..
try that.
Old Aug 18, 2004 | 01:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The relay for my '86 LG4 is next to the radiator on the passenger side.
It's not like the factory ever kept things in the same location so you could find them regardless of engine type or year.
Old Aug 18, 2004 | 03:02 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Yeah, the fan relays for my 88 LB9 are passenger side by the radiator. The stuff on driver side firewall by the booster are the MAF burnoff and stuff like that.
Old Aug 18, 2004 | 07:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Five7kid & tremo are correct on the location of the fan relays. In 1990 the location changed when they went to the MAP system and did away with the MAF power relay and the MAF burn-off relay. Incidently, these relays are the same relays used by the fans.
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
