Should I use positive seals on the exhaust valve?
Old Aug 18, 2004 | 08:14 AM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
After scrolling the valve seal stuff for 3 hours, I cannot come to a concensus.
Shoud I use Positive or umbrella type seals on the exhaust valve? I see some people have, and some people say it is a sure way to kill your valves.
Old Aug 18, 2004 | 09:36 AM
ede's Avatar
ede
i do or have. i never run umbrella seals
Old Aug 18, 2004 | 10:30 AM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
Originally posted by ede
I never run umbrella seals
For what reason??
Old Aug 18, 2004 | 11:05 AM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, I use positive seals (Sealed Power) on both the int. & exh. but I leave off the stock o-ring on the valve stem.
Auggie
Old Aug 18, 2004 | 06:57 PM
Vader's Avatar
I'd suggest the positive seals, stainless valves, and synthetic lubricant. GM offers positive seals on almost everything they build now (since about 1993). You can get seals from them, or many aftermarketers. The exhaust seals are different, and marked as such.
Old Aug 18, 2004 | 09:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I use these, or the equivalent, on everything I build for myself, and as many customer motors as I can get them to pay for them. Note that there are 16 in the package.
Attached Thumbnails Should I use positive seals on the exhaust valve?-valve-seals.jpg
Old Aug 18, 2004 | 09:07 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Okay, I saw these seals in a post by Tim (Traxion)...
Originally posted by Traxion in Can't rev pass 6000 rpm PART II
While you are there make sure you swap out those crappy valve seals with a set of vitons from TEA (picture here)
Now I messaged him asking him questions about them, never got an answer.
My questions are, will they fit stock LB9 heads, both intake and exhaust, without maching? Do I need to use the O-Rings also? Should I use them on both intake and exhaust?
Do any of you guys have information or experience with these?
Old Aug 18, 2004 | 11:31 PM
Auggie's Avatar
Well, like I said I use Sealed Power valve guide seals (XUA-MV1888) on both the int. and exh. even though I think they are for the int. valve only. I do not use the o-rings on the valve stems and this allowes oil to run down the valve stem through the split in the valve locks. These seals are for a .562" guide. Engine will not smoke on start up and valve guide wear seems to be ok. Just freshend up a set of 406 heads (12,000 mi) with this setup and the valve guides were fine. Vortec heads have nice valve guide seals but in my case (.562" guides) the OD on these guides would have to be machined.
Auggie
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
