what two wires do I check my TPS voltage with?
Old Apr 29, 2001 | 04:28 PM
EO273KiD's Avatar
There are three wires on the TPS, labled A, B and C. What 2 do I check to ensure smooth TPS voltage? I unplugged my TPS and at idle I didn't notice any change in the way it ran, i revved it up a bit and didn't notice any change once again... is this a bad sign? I only revved it up to about 2g... i think i might unplug it and drive around to see if there is a big difference... maybe this could be the cause of my slow et?
Owner of a 1989 IROC-Z Camaro, a.k.a. "The Babe Magnet". Painted a cheap metallic blue that chips off all too easily and covers over the IROC-Z decals on the doors, also has non-leaking T-tops, ps, pw, power rear hatch, working A/C. Mods: SLP intake runners, gutted MAF sensor, adjustable fuel pressure regulator, modified air spoil, 3.27 posi rear end.
Broken stuff: rear spoiler brake light, driver side lock, power antenna, tilt steering, rear end bushings, cracked passanger side ground effect, washer fluid tab, leaking exhaust and a rotted through muffler that sparks when the car bottoms out while driving like any 17 year old does.
Old Apr 29, 2001 | 05:17 PM
speedlvr's Avatar
Put the red probe in the middle one and the black one in the one on the right.
Old Apr 29, 2001 | 05:59 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Check out this link: TPS. Basicly, you want to slowly open and close the throttle blades, and look for sudden "spikes" or any uneveness. It should move smoothly from around .52V to 4.5V Hope this helps.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
EO273KiD's Avatar
My tps plugs in verticly.. its a 5.7 TPI, 89 IROC
Old Apr 29, 2001 | 06:01 PM
Steves ZZ5's Avatar
The wires are arranged top to bottom...
the top wire and middle wire are the ones you need to hook your digital volt meter to.
keep the TPS connected when you make the adjustment. to make things easier, straighten out two paper clips and slide them through the back of the Weatherpak connector, and then hook your voltmeter up to the paper clips. Or, you can make three jumpers and place the jumpers between the connector and the TPS socket. Whichever way you use, make sure you have good electrical contact with the jumpers or paper clips.
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
[This message has been edited by Steves ZZ5 (edited April 29, 2001).]
Old Apr 29, 2001 | 09:05 PM
daniel dekay's Avatar
can the same procedure be done to ckeck the tps voltage on a qjet equiped car too?
daniel
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
