What are these numbers on my pistons?
Old Aug 18, 2004 | 06:50 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I got this motor a while back, and I plan to build it up a little and drop it in my currently smoking 88 Iroc. When I took the heads off I saw this:
Some say 10 or 11 or 12 or 14. What do those numbers mean?
Old Aug 18, 2004 | 10:56 PM
FstBrd6point3's Avatar
they look like alignment marks.... piston pins are off centered and "need" to be installed with the pin offset to one side... looks like it is for directional purposes.
Old Aug 19, 2004 | 10:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The forward-facing mark, yes. I think there's a different explaination for the numbers.
Two guys in the piston shop got bored (no pun intended) one day. They got to talking, and one said, "I bet if we started stamping random numbers on the top of these pistons, it'll really drive somebody nuts 15 or 20 years from now when they try to figure out what they mean."
Old Aug 19, 2004 | 11:02 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Seriously? Weak. I was hoping it was a sure sign of a rebuild or something!
Old Aug 19, 2004 | 12:12 PM
five7kid's Avatar
A "20", "30", or "40" might indicate that. But, I'd hope they were all the same number in that case.
They're probably some sort of production tracking #, like shift, lot, date, or some such number.
If you want to know if the engine has been rebuilt, check the bore diameter.
Old Aug 19, 2004 | 12:31 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
What should the bore be, if it has not been bored?
Old Aug 19, 2004 | 12:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looks like it should have been a 4.000" bore block.
Old Mar 24, 2005 | 05:41 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, I took a micrometer, and the inside diameter is almost exactly 4". I know that doesn't make sense, I think it was 3.99 or 4.01 or something like that. Is that stock, unbored?
Old Mar 24, 2005 | 05:59 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it was almost 4? are you sure this is a 350 and not a 305?
Old Mar 24, 2005 | 06:09 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yes, the block number checks out to be a 1969 350.
NZKnight
Oct 15, 2015 02:47 PM
okfoz
Oct 13, 2015 02:19 PM
skinny z
Oct 5, 2015 06:23 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
Dragonsys
Sep 25, 2015 03:51 PM
