Weak spark question
Old Aug 22, 2004 | 01:13 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Weak spark question
How bright should the spark be if you hold the boot away from the plug to check for a spark?
Better yet, how can you check for a weak spark?
Scott
Old Aug 22, 2004 | 02:01 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Pull a spark plug, hook up the wire, and hold the plug against the head while cranking. It should be about as wide as the center electrode, white or blush white, and audable if i remember.
Also, careful you dont get shocked. It hurts...
Old Aug 22, 2004 | 02:15 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A better idea would be to use a spark tester.
Old Aug 22, 2004 | 04:15 AM
Morley's Avatar
Good spark= blusih white
Bad spark = red-orange
Old Aug 22, 2004 | 12:58 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Be carefull with aftermarket ingnition boxes thou. Ive seen some that will be red at lower rpms and white at higher rpms. While the red at lower rpms may seem bad its actually operating just fine.
Old Aug 22, 2004 | 03:22 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
No aftermarket box here.
I've had this problem before and it was the distributer. I wonder if it was replaced waith a cruddy rebuilt one and it's going south again.
Anyway of testing the distributer without taking it out?
Old Aug 23, 2004 | 01:45 AM
dankhound's Avatar
Car: 91 RS
Theres really no test for it. Its just a visual on the cap and rotor.
Old Aug 24, 2004 | 12:06 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Actually, I was thinking more along the lines of the electronics.
Do you have to pull the distributer to check the module or can it be done in car?
Old Aug 24, 2004 | 12:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, and no.
Easiest way is to take it out, take it to a parts store that has a tester, and get them to do it.
Why would you want to check for "weak spark" in the first place?
Old Aug 24, 2004 | 09:33 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Actually, it was for a possble no spark situation.
A few years ago, my car just died. It would crank but wouldn't start and since I was near a pep boys, I pushed it there.
They told me it was my distributer and replaced it.
It happened again the other day. It wouldn't start and when I checked for a spark, it looked pretty small and weak. The car then started but as I was driving, it cut out. It started up again and I made it home but I wan't to test the ignition system before I drive it anywhere else.
Old Aug 24, 2004 | 11:21 PM
Morley's Avatar
Sounds like the ignition module might be over heating and crapping out.
Old Aug 25, 2004 | 01:25 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Use a GM module and accept no substitute. Also remember to clean the mounting surface and use plenty of heat sinking grease when installing a new module.
Old Aug 25, 2004 | 05:38 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Why no sub? Have you had or have first hand knowledge of anyone haveing a problem with a quality aftermarket module from Accel or Pertronix? Please explain your statement on no substitute.
Goes without saying about the cleaning and use of thermal compound ("grease"). The best heatsink compound is called Artic Silver and it's available from the computer nerd/geek suppliers. It has much higher thermal conductivity than the normal stuff.
Old Aug 26, 2004 | 03:21 AM
Morley's Avatar
Originally posted by Tremo
Why no sub?
The "aftermarket" modules have been notorious for failing in a very short time. And the "high dollar" ones from pertonix, mallory etc. are no better than a factory GM module, they just cost more.
Red iroc-z 305
Sep 30, 2015 05:22 PM
tricky1
Aug 23, 2015 01:17 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
