When swapping cam do i need new lifters?
Old Aug 22, 2004 | 07:22 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
Im swapping from LO3 cam to Lt1 cam with 081 heads... do i need new lifters or can i reuse the stock lifters?
Old Aug 22, 2004 | 07:27 PM
yugi-master's Avatar
Car: 1987 Trans-Am
Engine: LG4
is it a roller?
if this is roller to roller swap then you can reuse lifters
if this is flat tappet cam then you need new lifters on every cam change unless its "same cam same lifters" used then just make sure all lifters go back in the exact same spot they came out of.
Old Aug 22, 2004 | 07:34 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
Yes its hyd roller cam... so i dont need new lifters correct?
Old Aug 22, 2004 | 07:40 PM
Car: 1987 Trans-Am
Engine: LG4
nope your good to go as long as the lifters are in good shape your reusing.
anesthes
Mar 10, 2016 10:35 PM
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
