SES light came on today
Old Aug 22, 2004 | 07:45 PM
'89 superbird's Avatar
Hi all,
Drove my car last night to a show and it was fine. This morning I went out to start it and it didn't crank right up. It turned over several times before it finally caught on. Once it did start, I got the SES light. I had a show to go to today and drove up the street to the gas station came back home and was not going to go. Turned the key the next time and it fired right up as usual (except this morning first thing) and no SES light.
So I drove it to the show and it was running fine, no codes, gauges all fine. Sat at the show for a few hours and when I tried to start it, same dry start, not as bad as in the morning but needed to turn it over 3 times. SES light now on. Drove it for a bit and thought I would stop after a short distance, turn it off and start again and it would be gone. No such luck. Fired right up but still light on. Babied it home and stopped it and then fired it right back up and no SES light.
Went out a couple of hours later and cranked it and had the SES so I turned it off and read codes. It is pulling a 24 which from the Haynes is a VSS which if car not moving ignore. Also pulling a 54 which describes carburator and also says check ECM. Drove it tonight and the SES light is still off and on. Very intermittant.
Sorry for the long winded description but hoping it helps to solve this issue.
thanks
Scott
Old Aug 23, 2004 | 01:39 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
What kind of car is it? 54 could be a problem with the fuel pump circuit. That would definatly explain the hard starting.
Old Aug 23, 2004 | 07:17 AM
Sorry, meant to put all the details in for the car. It is an 87 Iroc Z with a 350 tpi. Let me know what you think
thanks
Scott
Old Aug 23, 2004 | 08:04 AM
A 9 Year Wait's Avatar
Car: 1989 IROC-Z 305 TPI
I would have to agree with the fuel pump. My 89 Iroc had trouble starting like that, turned out that the pump was going out, and there is like a checkvalve to keep the fuel lines full, my valve was going out and would drain the fuel lines. When I tried to start it, the pump was having to prime the lines again...hope that made sense...
Old Aug 23, 2004 | 10:10 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your code 54 = Fuel pump circuit (low voltage) and your code 24 = Vehicle Speed Sensor (VSS) and can be set if there is not constant voltage on that circuit. Just a thought
Old Aug 23, 2004 | 10:11 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Aug 23, 2004 | 11:12 PM
dankhound's Avatar
Car: 91 RS
Dam trickster,
If you make one more two page post with info i really wish i had from those service manuels im gonna come down there and steal them from you. A picture really does say a thosand words. hehe
eightsixseven
Dec 16, 2024 01:50 PM
777Shock777
Oct 29, 2015 04:30 PM
spaigo
Aug 21, 2015 07:46 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
