cam change out?
Old Aug 23, 2004 | 07:29 PM
lilfrancisco's Avatar
cam change out?
when i changed my cam out for a new one on my 1982 305 z28 i diden't put a new timing chain on(it was only 8months old) will it really affect my timing? little birdies keep wishpering in my ear that i screwed up...
Old Aug 23, 2004 | 07:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If your chain was in good shape to start with, I doubt it will be a problem, bit its always a good idea to change it out for a new one.
Old Aug 23, 2004 | 08:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If it's only 8 months old, it shouldn't hurt anything. That also depends, though, on how many miles were put on in those 8 months.
But, like A^2 said, it is always a good idea to get a new timing set with a cam swap.
Old Aug 25, 2004 | 11:53 PM
thanks guys,but could it affect my timing?
Old Aug 26, 2004 | 12:00 AM
DeWynter's Avatar
It will affect your timing as time goes on its the same for all timing chains, they all stretch. If you had an EFI it wouldnt be as much of a problem as the spark advanvce can make up for the loss in timing on the chain. If you are really woried about timing go to a gear set. If you have no knock sensor It will keep the timing good for much longer but will also make the engine a bit louder as you will hear the gears.
Old Aug 31, 2004 | 12:00 PM
i'm in california, isen't gear drive illeagel in california? i'd love gear drive but always thought i coulden't have it. maybe im the dork....
Old Aug 31, 2004 | 01:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Don't worry about a gear drive. Too much money, not enough gain with too much to risk. If you're worried about timing, just get a good aftermarket double chain design.
Besides, for many, the whining noise gets old after a while.
Old Sep 9, 2004 | 12:43 PM
DeWynter's Avatar
What risks are you talking about?
Old Sep 9, 2004 | 03:50 PM
ljnowell's Avatar
I'm not sure how gear drives are nowadays, but when i was younger I could remember people replacing the damn thing about every two years.
Old Sep 9, 2004 | 07:27 PM
Air_Adam's Avatar
That and they make a terrible racket like you wouldn't beleive. Chains are nowhere near as annoying.
Old Sep 9, 2004 | 08:22 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
The gear drive discussion aside, David Vizard says that an average timing chain will stretch about a half of a degree after 5000 miles, not enough to be noticable in most cases. If you've changed the cam, you had the dizzy out. I would think the issue might be in proper dizzy replacement and/or/thus timing.
Old Sep 10, 2004 | 07:11 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
so... what you're saying (in my case) is that my chain has 31,600 miles on it and with putting in a new cam i need to change the chain?
KAM
Old Sep 10, 2004 | 03:20 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
If I had it apart I would have replaced it but I wouldn't go to the trouble now, no older than your chain is. What I was infering was that to change the cam you obviously had the distributor out. And IF you're having timing issues now then it could be improper dist. installation. Heck that's the one thing that still throws me after all these years. Every time I put a dizzy in, I'll end up moving it at least once.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
nuggie
Aug 25, 2015 01:27 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
