car surges when heater/ac is turned on
Old Sep 9, 2004 | 05:23 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
When I turn my heater/ac controls on the car will somtimes start surging and run almost like there is a fuel delivery problem. It only happens when the controls are on.
The only thing that comes to mind is vaccum related. has anyone else had this problem.
Old Sep 9, 2004 | 06:41 PM
86'Bowtie's Avatar
Car: Hugger Orange Camaro
Bad sensor maybe. It is fuel injected right?
Old Sep 9, 2004 | 08:03 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
Well I can't see what sensor would interact with my heater controls but maybe I am stupid.
Old Sep 9, 2004 | 08:04 PM
86'Bowtie's Avatar
I could be the stupid one, but it was just a suggestion to look at.
Ya never know.DUECE
Old Sep 9, 2004 | 08:13 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Could it be an a/c system problem causing the compressor clutch to cycle too often? Just a thought.
Old Sep 9, 2004 | 09:16 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
I thought of that and unplugged the clutch and it still does it. It does it on all settings as well. I think the ac is active on defrost and ac. it will do it with the thing set to vent as well. I feel like a complete moron I am stumped.
Old Sep 9, 2004 | 10:41 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
OK, good troubleshooting so far, what year is this?
You're right on about the ac vs vent deal. What about the fuel filter or in-tank pickup. The only times I've had that problem where a semi-plugged fuel filter, bad O2 sensor, and a vac leak.
Old Sep 9, 2004 | 10:55 PM
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
well it is a 90 350 tpi. I have not worried about the fuel supply as the car runs fine until I switch the heater on. If it was a fuel issue my logic tells me the problem would be all the time unless I am missing something.
I can be driving down the road with the heater on and the car surging then turn off the heater and intantly the car runs perfectly.
Old Sep 10, 2004 | 03:23 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I agree with your logic. That leaves you with the vac. operated heater controls and associated parts.
Wade787b
Sep 29, 2015 01:15 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
