random stalling, 92 LO3 305
Old Aug 26, 2004 | 11:25 AM
kalooter's Avatar
Car: 1992 Pontiac Firebrid
Engine: 305 V8
hey guys, I'm new to this, just registered...first post
I just got a 1992 LO3 305 TBI. For some reason, the car just randomly stalls. It starts up great. Then idles fine but if you let it idle for a little while (like 5 minutes), sometimes it will stall, sometimes it will be fine. Also as I drive, the tach flucuates sometimes. It will jump from like 2,000 to 1,000 back to 2,000 within like a second. It has also even stalled two or three times while driving at like 30 mph. It stalls while driving only after accelerating then when you let off the gas the rpm's just drop all the way down. If anyone has any clue, please let me know. Thanks, Jimmy
Old Aug 26, 2004 | 11:30 AM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
welcome to the boards my brother!! no literally... hes my brother
want to let everyone know i gave him some tips like how to use the search button and sall that so he is an experianced noob
of course he gets an f-body just as my trans blows..
anyway i tested the car out and really can't pinpoint his problem, i was thinking fuel filter, maybe vacume line,
anyone else with suggestions would be great
Old Aug 26, 2004 | 12:44 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
My lo3 did that when the fuel pump was dieing. I would look into your fuel situation and see whats going on. I hope it isn't the fuel pump....cause most of us know its a PITA.
Old Aug 26, 2004 | 08:19 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Sounds like maybe a fuel pump. But also check the idle air control (IAC). Sometimes they can be a problem. Usually it will be hard starting when they act up, but ya never know.
Old Aug 26, 2004 | 11:08 PM
Transmission: 4l60e
When my pump was dieing it would start right up. Then the idle would go crazy. It would jump around and if I sat there and revved it up sometimes it would smooth out and sometimes it wouldn't. Then for 2 months it stopped and ran pretty good. Then one day the pump was completely dead and that was it. Changed the fuel pump and the car ran perfect.
Old Aug 26, 2004 | 11:22 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Welocme to the forum. I'm sure you'll have this mystery figured out in no time.
Old Aug 27, 2004 | 09:37 AM
kalooter's Avatar
Engine: 305 V8
thanx for the help
hey guys...thanx for the ides, seems like it would be the fuel pump
thats ok tho, its my first one so im alittle excited to change it hopefully my bro will want to tho, then from what it sounds itll be my last one changing lol....thanx again all peeeacee
Old Aug 28, 2004 | 08:45 AM
CaysE's Avatar
Whew... dropping the rear end and gas tank as your first project... well, at least you'll be learning a lot. Welcome aboard!
Old Aug 29, 2004 | 04:08 PM
Transmission: 4l60e
Fuel pump was my first project. I did it in 2 days.
Many projects have spawned since.
Old Aug 29, 2004 | 10:51 PM
Gr89RS's Avatar
Car: '02 Z06
Hey how do you check the idle air intake or whaever and does replacing the fuel pump cost a lot??????
jklein337
Sep 19, 2018 06:23 PM
777Shock777
Oct 29, 2015 04:30 PM
Bryan F
Aug 18, 2015 02:28 PM
fonzie85
Aug 13, 2015 11:50 AM
