Dipstick!
Old Aug 26, 2004 | 09:13 PM
83TAPACECAR's Avatar
Car: 83 TRANSAM
Transmission: AUTO
Dipstick!
I TRADED MY BROKEN PLAY TRUCK FOR THIS 83 TRANS AM PACE CAR WITH A 350 IN IT. THIS CAR ORIGINALLY HAD A 305 IN IT. ANYWAY MY DIPSTICK HOLE IS BEHIND THE EXHAUST HEADER WHERE IT CONNECTS TO THE DOWN PIPE SO I EITHER NEED A VERY THIN DIPSTICK, NEW EXHAUST OR THE RIGHT ENGINE. I GUESS I COULD PLUG IT AND CHANGE THE OIL OFTEN. BUT THAT IS TOO MUCH WORK. I NEED A SIMPLE SOLUTION. THANK YOU IN ADVANCE....
Old Aug 27, 2004 | 02:13 AM
SchwarzCamaroRS's Avatar
are you sure that its the oil dipstick? the one on the drivers side behind the exhaust manifold is the transmission dipstick... the oil one is closer to the middle of the engine. the 350 and 305 are almost identical on the exterior, depending on what year 350 it is.
Old Aug 27, 2004 | 01:33 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Do what I did... get a junkyard dipstick and tube (or get the chrome Mr. Gasket one) and rent a tubing bender. With the bender, just 'tweak' the tube so that it will fit between the head and manifold so the dipstick can still come out.
Not hard, just takes some time.
Old Aug 27, 2004 | 07:54 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
another option would be you could get an oil pan that has the dip stick tube through the side of the oil pan instead of going into the block. if you go this way you will need to plug the dip stick hole in the block.
i feel a MOD post coming
Old Aug 27, 2004 | 07:57 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
WELCOME TO THE FORUM.
(durn caps lock key).
Oh... and the potential in that car is obvious... at least to me.
Old Aug 28, 2004 | 11:33 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
i have a similar problem, i just replaced my dipsitck because I broke my old one when i was taking my heads off, i orderd the exact one from gm but now whenever i take the dipstick out, oil runs all the way up to the top, wayyy past the full line, so i have no idea how much oil is in there, and i have check both when the car was just run and when it has sat over night.
Old Aug 29, 2004 | 10:31 PM
Nordbert's Avatar
You probably have a pre-1980 engine block. I use an oil pan adapter block ( Goodson OSD-60 Bolt-on Dipstick Conversion Casting) and a 1980 -1984 oil pan and a left hand dipstick for a 305. It is a PITA with the engine installed, however. Goodson also makes an exhaust flange spacer plate which creates clearance for the right hand dipstick. Its part # is CHC-10 Head
bolt conversion. It was designed to adapt the older heads which
had 6 exhaust bolt holes to 7 holes so the later F-body manifolds
could bolt to the pre-1979 heads. The CHC-10 looks like a 1/4"
thick header flange. See your favorite auto machinist and ask to see his Goodson catalog.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
NZKnight
Oct 15, 2015 02:47 PM
KCG
Sep 23, 2015 09:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
