what is the best starter for a 3rd gen/
Old May 2, 2001 | 04:32 PM
rsupersport2k's Avatar
I have a real bad problem with my cars starter. I have put like 3 new starters all from high low o'reilly and all different manufacturer's. My car will either just click 2 or 3 times then turn on or it will not do anything but turn on the guages. Is it the starter brand or something else?
Old May 2, 2001 | 04:45 PM
irocbsa's Avatar
Order one of the high torque units from Summitt, they have a few different brands.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old May 2, 2001 | 04:49 PM
vortech305's Avatar
I bought a Duralast from Autozone. DOnt know the quality, but i could give a damn since i have a lifetime warranty for their starter.
Old May 2, 2001 | 05:06 PM
The ODB's Avatar
CSI makes the best one that I've ever used or known of experiences from other people. They aren't cheap but they do exactly what they claim to do and will work even with a weak little lawn tractor battery. Mine weighs about 6 lbs and the position of the starter motor can be adjusted to clear exhaust.
ODB
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
* vizit miy homepayge * http://www.geocities.com/trailerparkpage/
Old May 2, 2001 | 05:18 PM
RICHRAD's Avatar
Most commonly that is a battery or alternator problem after changing to another starter with no luck.
Old May 2, 2001 | 08:48 PM
ede's Avatar
ede
i have a GMPP mini starter, fits sbc and 90*v6s. it also is adjustable for clearance and weighs under 10 pounds.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 2, 2001 | 10:36 PM
82 T-TOP's Avatar
Had the same problem with my starter, but only when the engine was hot. It would just click. Had it checked out along with the soleniod and no problem. Was told by the auto elec, it is a commom problem on chev motors (exhaust to close to starter and heats it up)so he fitted a relay so starter takes current direct from battery and not through the soleniod. cheap fix. Will start now no matter how hot it is and even if the battery is low.
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
Cleotiz
Sep 16, 2015 08:02 AM
Magman
Sep 13, 2015 12:07 AM
Formula_88AE
Sep 3, 2015 01:47 PM
