Broken Trans mount on engine block.
Old Aug 28, 2004 | 01:56 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
See the picture below. Is this enough reason to pitch this block? Can it / should it be fixed? How much of a safety issue is it?
Thanks,
Jason
Old Aug 28, 2004 | 02:08 PM
ljnowell's Avatar
damn my bad eyes, but is it just one bell housing bolt?? If so, forget about it. Put in the rest, and dont think about it.
Old Aug 28, 2004 | 03:13 PM
ede's Avatar
ede
yeah i tihnk all in all it wouldn't matter. if you want to do something you could build it up with epoxy and redrill and tap it.
Old Aug 28, 2004 | 05:25 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Thats definatly not a big deal. If your really worried about it do what ede suggested. Just think about it. Thats one of like 9 bolts holding the trans on along with the two dowels.
Old Aug 28, 2004 | 05:34 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
I can see your points. It's my first time and I don't really recognize what is important versus what ain't a great big deal.
I think this engine has been touched before. There's some blue goop at the bottom of the timing chain cover, the timing cover looks like someone has pried at it before, and there's absolutely no sludge at all under the valve cover. Maybe I'll get lucky and it really is just some seals to be replaced.
Jason
Old Aug 28, 2004 | 09:32 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Jason
i wouldnt worry about that one bolt ,
the blue goop is probably gasket sealer ,
and that means someone has replaced the timing chain or front seal on it before.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
lakeffect2
Aug 23, 2015 08:44 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
timonator
Aug 11, 2015 09:56 PM
