Unkown Heads!! Please Help!!
Old Aug 30, 2004 | 08:02 PM
moneyman380's Avatar
Car: 1991 Z28
THese are off a friends 350 but i have no idea if they will work with my stock 350 tpi.
The only numbers i found were F178 GM40 3911032 all around the valves.
Old Aug 30, 2004 | 08:12 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
If you did a you would have found a site www.mortec.com. You are welcome.
Old Aug 30, 2004 | 09:23 PM
Car: 1991 Z28
I went to that site and they said the heads were for a 307 or 327 with 70cc chamber off a 1968.
But will they work with a 350tpi or am i just wasting my time?
Old Aug 30, 2004 | 10:09 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
With the '91 manifold? If you have the material in the manifold to alter the two center intake bolt holes on each side then yes you could use them. I'd see if anyone can pop in and recognize if they are any good. You may be better off with the heads you have on there now.
Old Sep 1, 2004 | 01:26 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Do they have accessory holes? Likely not if its a '68 casting. If they don't have them, you are SOL. If they do, go nuts
Old Sep 1, 2004 | 11:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
1968 307 or 327 = granny's engine.
1968 was the last year of the 327 and the first year of the 307. They were the "entry level" V8's, and only came with 2bbl carbs. They had heads to match the 2bbl carb "performance".
You can go nuts on them, but after all the effort, that will also be your conclusion.
Old Sep 1, 2004 | 11:43 AM
five7kid's Avatar
You didn't happen to measure the intake valve diameter, did you? As in 1.72"?
Old Sep 1, 2004 | 11:45 PM
Car: 1991 Z28
I havent pulled the heads yet so i cant measure the valve, but a mechanic i know offered me $100 for them. Should i sell ?
Old Sep 2, 2004 | 12:02 AM
five7kid's Avatar
I didn't get that quite right. 1969 was the last year of the 327. Those heads are one-year wonders because they went with accessory holes in 1969.
Without the accessory holes, you'd be hard pressed to make good use of them, regardless of performance potential.
Old Sep 2, 2004 | 10:13 AM
Car: 1991 Z28
I checked this morning and they dont have assy. holes so i guess there useless. that would also explain why the power steering was never hooked up.
Old Sep 2, 2004 | 12:06 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Well, then, sell them to the mechanic who's offering $100. Not a total loss, eh?
Are you trying to upgrade the 350 in your Camaro? If so, just port and polish the stock 083s on the L98 and you'll have a hopping little mouse
Old Sep 2, 2004 | 12:54 PM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
any 307 is a waste of time. however the 327 is quite the power plant. Big bore+ short stroke= lots of upper rpm fun, and power. There are quite alot of impressive 327s from the factory, solid cams.... Holley carbs w/ mechanical secondaries..
Old Sep 2, 2004 | 01:25 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Yeah, don't forget the old 350 HP 327 Vette motors. No slouch. Didn't they also make a 327 with a solid cam and 365 HP? Wasn't that the old "30-30" Duntov cam?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
