Engine will run eratic at times, other times great...read on...
Old May 4, 2001 | 07:36 PM
rurockn's Avatar
I have a v6 82' camaro. Engine will run absolutely perfect sometimes, then sometimes it will start to drop rpm's while in park or in gear at idle and then dies. If you are moving there are no problems at all. I have a new carb and plugs on the car, wires should be OK the are about two years old. Could it be some sort of sensor? Anything will help! thanks
Old May 4, 2001 | 08:03 PM
coach's Avatar
How many rpm's is it dropping? When an a/c compressor's clutch engages, the engine's rpm climbs a bit(because of the extra load);when it disengages the rpm's drop down a bit. But as far as an engine dying, I have another question. What is the most stable rpm that the engine is holding, both in park and in gear. The idle will also be a little higher in park than when in gear. Normally, an engine with an automatic trans. should idle about 750rpm's. One with a maual trans. should idle a bit lower, about 600rpm's if I'm not mistaken. When you're idling, is it a rough idle? Does anyone else have any input?
Old May 7, 2001 | 03:32 PM
theformula's Avatar
If you have access to a diagnostic tool try to verify what the volts of your battery is at. Do you actually hear the fuel pump powering down then up. I had a similar problem. Believe it or not a penny fell down my cigg. lighter and was causing my car to surge and die.
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger(SN93 upgrade), Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5200rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old May 7, 2001 | 05:31 PM
rurockn's Avatar
The idle problem happens while in gear, not in park like I accidentally posted above. It will only happen about every other day the car is driven though, thats what is weird. It jumps from about 400-800rpm on and off then dies, if you put it in park or hit the throttle it will even out. Any ideas?
thanks!
[This message has been edited by rurockn (edited May 07, 2001).]
bryan623
Mar 22, 2021 06:43 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
