Engine Problems
Old Sep 3, 2004 | 12:29 PM
tic_tac's Avatar
Car: 1989 Camaro RS
Engine Problems
My car is an 89 Camaro RS with the MPFI 2.8L V-6 and its doing something really funnky. It doesn't die totally but the engine seems to cut out, but comes right back. Then this morning I start it and it dies but when I try to restart it nothing happens, its like there was no power, but I had to have some power because the dome light came on when I opened the door. Then after I waited for about a min or two I tired again and it started no probelm. I let it run for about a min to make sure it wasn't going to die and it doesn't so I take it out and it dies at the first stop sign. It starts fine then on my way to school it starts to cut out and in again so I pull over and wait. Try to start it again nothing, so I wait again and try starts fine and no problems all the way to school. So does any one have any idea what might be causeing this and what I need to do to fix it?
Old Sep 3, 2004 | 04:43 PM
Zokal's Avatar
Car: 1989 Firebird Formula
Engine: Chevy TPI 350
Transmission: A/T 700 R4
Try Ignition Coil
If I were you, I would check the ignition coil. Sometimes when they get hot, they will act up. Try replacing it.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
