chattering
Old May 7, 2001 | 03:30 PM
BlackIroc's Avatar
chattering
I have chattering from what I believe to be the smog pump, should i Just replace or is it something else. Has anyone ever had this problem. Also it gets louder with the rpm so i'm almost positive its an accesory
Old May 7, 2001 | 03:41 PM
Steve89GTA's Avatar
chattering is usually associated with clutches. If you mean 'popping' in the exhaust like backfiring, it's probably your diverter valve from your Air pump. Good time to remove it.
Old May 7, 2001 | 03:52 PM
BlackIroc's Avatar
No it is not the clutch, it is a pretty constant chatter every 3 seconds coming from the smog pump. It is not back firing in the exaust, any idea please help
Old May 7, 2001 | 06:02 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
how do you know it is coming from your smog pump? take the belt off to see if it is. by the way, what year and engine do you have, because usually, chatter, if not the clutch is really associated with carburators running on the wrong air/fuel mixture. if you have a V-belt config, take the belt off and runn it to see if thats your problem. let us know
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
Old May 7, 2001 | 08:03 PM
BlackIroc's Avatar
i used a mechanic stethescope and it seems as though it's coming from the smog pump. it is a serpentine belt and i haven't had time to take it off and check the smog pulley. I got a new smog pump and will try putting it on. the chattering is an accesory and has nothing to do with the motor. Any ideas???
Old May 7, 2001 | 08:05 PM
BlackIroc's Avatar
oh, its a zz4 350 with tuned port injection so it isn't the carb, also i'm sure it is not my motor, someone said it could be a water pump though
novaderrik
Aug 10, 2015 12:44 PM
Hung Start67
Apr 23, 2003 04:18 AM
maksik7
Apr 19, 2003 02:43 PM
JDMZ28
Mar 6, 2001 08:14 PM
