Cleaning carbon buildup?
Old May 4, 2001 | 07:08 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Hey all,
I think I remember reading here about using tolulene (as a fuel additive) or something for cleaning valves and stuff on an older, gummed up engine. Thinking about putting a used stock 350 in my 5 speed car and wondered if there is such a "miracle" cure .
thanks for any help
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission---FOR SALE---
Looking for a V8, preferably 4 or 5 speed Camaro with NO T-tops (wanna trade?)
Old May 4, 2001 | 07:24 PM
ede's Avatar
ede
misting water i nthe carb/throttle body works real good. was a big topic here a week or so ago, do a search and read all that was said about it.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 4, 2001 | 07:54 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Will do, thanks
I did a search on tolulene but didn't find anything...new keyword is water
thanks
Clem
ps, I'm used to working on engines that are lucky if they see 500 miles . I'm really more of a chassis guy.
Old May 7, 2001 | 06:24 PM
coach's Avatar
I remember watching the show "motorweek" a while back and Pat Goss did a segment on this subject,showing different options. One was of a machine that circulates finely crushed pecan shells or walnut shells through the engine to clean up all of the build-up. I'm not sure of the name of the equipment or how exactly it operates.
Has anyone heard of this?
Old May 7, 2001 | 07:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The pecan shell thing is actually a regular service in the BMW product line, to be performed at soem interval in the maintenance schedule... they rev the motor up about as high as it will go without blowing up, then dump several pounds of them into the intake... makes a foul smell and a huge cloud of evil smoke... I have no idea how much good it does, but BMW must be convinced.
ICON Motorsports
Old May 7, 2001 | 08:18 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
How would someone with tpi use such a cleaner
1986 TPI 305 TRANS AM
Old May 7, 2001 | 08:45 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
RB,
Think of the engineer at BMW that came up with that idea.....do you think he had a hard time selling it to managment? I would have liked to seen the looks on their faces...."you want to do WHAT with that engine!?"
Old May 7, 2001 | 08:57 PM
steve8586iroc's Avatar
Check this seafoam stuff out http://w3.one.net/~roz/cars/z28/seafoam.html sounds crazy but it my work.
Steve
FastBroker's Avatar
WOnder if the cats like them shells...
I use ATF mixed with gas in a spray bottle. rev the engine up and spray it in like carb/TB cleaner. when the ATF hits the carbon buildup, it makes the carbon crack, and it flakes off and goes out the engine and also, the detergents in the ATF clean the valves about as good as any product I have ever seen. Some use straight ATF but I use about half ATF, half gas. BE CAREFUL!!!
Works REAL well and I do it to all engines before I remove the heads to clean the pistons and comb chambers... Search the internet and you should be able to find something on it.
Old May 7, 2001 | 09:28 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I've seen lots of people say what they use and then swear by it and say how good it works. Well now for the real question...How the heck do you know it works if you do it before you take the heads off and then possibly never take the heads off? There's no comparison visually without orthoscopes and such coming into play. I'm just curious.
Does anybody feel the ATF might have adverse affects in other aspects, catalytic converters, seals, etc?
thanks for all the discussion
Clem
Old May 7, 2001 | 10:38 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
best stuff i've found is gm's top engine cleaner. it's just really tricky with a tpi. best going in with it through the pcv valve vacuum hose.
Old May 7, 2001 | 10:43 PM
zee28's Avatar
Car: 86 iroc
I use the gm top engine cleaner,have no idea if it works?
~mike~86 IROC-Z
Old May 7, 2001 | 10:55 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
Aren't any of you old enough to remember dumping uncooked rice into the intake to clean carbon? That used to be SOP on flathead military engines, like Continentals and Fords.
Am I THAT freakin' old?
BTW - Water mist injection works VERY well in a warm engine.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
[This message has been edited by Vader (edited May 07, 2001).]
Old May 8, 2001 | 01:37 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Now there's a response I really trust. So it works good on a warm engine?
SOLD!
thanks Vader
Clem
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
WhteRbt
Sep 21, 2015 09:48 AM
