Idle probs and more
Old Sep 8, 2004 | 05:48 PM
Allan Dollaway's Avatar
Car: 1988 trans am
Engine: 305tpi
Idle probs and more
Hi group,new to the board but need help,I have looked over many past posts already but have questions.86tpi 700r4, All of a sudden runs very rough and idle problems. Local dealer shotguns fuelpump and have them replace valve gaskets at same time.Oil sending unit on back is prob shot as gauge goes allover. Said original pump not keeping up,110000 miles. Doesnt seem to fix the problem.They replace EGR , solenoid and TPS. On test drive it now wont go into overdrive till 3000rpm and wont hardly start. Pulled wires off mass sensor and in a brief time loads up and quits.Runs better off idle they say but check engine light still on and bad! idle.Only code ever was 42. Never had any of the other stuff till they got it. They did also do wires,plugs,cap... Any ideas would be greatly appreciated. Thanks Allan
Old Sep 9, 2004 | 09:47 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You paid for them to fix it but they didnt. I would take it back there and have them fix it for free. Code 42 is an ignition problem. Check for loose wires around the distributor. Not plug wires, the smaller wires.
junior419
Apr 7, 2025 11:35 AM
86IROC112
Nov 27, 2015 09:54 AM
customblackbird
Oct 1, 2015 04:30 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
