AIR in NJ
Old May 9, 2001 | 02:48 PM
camaro6spd's Avatar
AIR in NJ
Do I need the have the AIR system in my car for it to pass inspection in NJ? Does anyone know a good set of inexpensive headers with the AIR system if I need AIR.
Old May 9, 2001 | 03:46 PM
SpeedStar's Avatar
Jegs sells a set of Hedman Headers with air. It comes complete with the y-pipe and O2 sensor fitting. About $310
1991 Camaro Z-28 305ci 230hp
1985 Camaro Coupe 331ci 300hp
http://www.geocities.com/speedstar38...Speedstar.html
Old May 9, 2001 | 06:09 PM
camaro6spd's Avatar
what do you think about those headers
Old May 9, 2001 | 06:15 PM
SpeedStar's Avatar
I have some hedmans on my 85, I was looking into those ones for my 91. Hedman is really good quality too. As soon as I get the cash those hedders are mine.
Old May 9, 2001 | 06:23 PM
camaro6spd's Avatar
great, any arguments againts them? don't the TES headers (with AIR) have the y-pipe too for ~$313? Which do you think is better, I know SLP has them but for over 400, i say no.
[This message has been edited by camaro6spd (edited May 09, 2001).]
Old May 9, 2001 | 06:26 PM
SpeedStar's Avatar
I haven't seen those hedders myself but I would think they're probably good since I haven't heard anything bad about em. Can you find them at nextgenparts.com I'll look into them a little bit more.
Old May 9, 2001 | 06:37 PM
camaro6spd's Avatar
Well, next gen want 409.99 but summit wants 313.99 for the same thing,
An edelbrock tubular exhaust system replaces the stock manifolds and y-pipes...comes with hardware, gaskets, OEM-type connector flangers, heat stove, air injection, and 02 sensor fitting were applicable....
1986-90 Camaro Iroc, z-28/Firebird formula, TPI single catalyst...5.0L/5.7L...313.95, part number edl-6872
Old May 9, 2001 | 06:51 PM
SpeedStar's Avatar
Looking at that I would probably go with those ones. For the extra buck you get all the gaskets and other needed parts. I will probably end up going with those instead. Looks to be alot better.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
