help with unknown hole
Car: 1982 Firebird
Engine: 355 CID
Every now and then a problem will surface that is so small that it almost doesn't warrent concern. THIS IS NOT THAT TIME. I feel like an idiot asking this but I must anyways. I replaced the stock 305 in my T/A with a newer 350 from a chevy caprice. The newer engine has an additional plug hole that it an inch or two above the regular drain plug hole. It is about 1 1/2" in diameter, maybe larger. When I first started the engine up, the oil pressure was through the roof. After a week or two of tests and tuning, I noticed a leak from under the engine coming from the location of the unidentified "hole". I looked closer to see that the plastic plug that was once in place had nearly desentigrated into nothing more than a thin coating around the threads. I have asked others for input, but unfortunately, everyone scratches THEIR head and looks at me as though I have two of them. Not much is known of the engine except it was bought from a local police auction when they auction off their vehicles. I am told it had about 60,000-70,000 miles when it was pulled (tax dollars at work, they replace them every few years whether needed or not.) Can anyone tell me what this extra is for?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Welcome to TGO!
Depending on what year Caprice 350 was from, the hole was probably for an oil level sensor.
Car: Z28
Engine: Sb2.2 406
Re: help with unknown hole
Car: 1982 Firebird
Engine: 355 CID
location
If you are looking at the oil pan, it will be about about 2 inches +/-above the hole for the oil drain plug at the base of the oil pan. The engine is either a 92 or 93 based on the date code.
Stekman, if it is in deed an oil level sensor, would you be aware of any kind of filler plug that is made to be placed into it when it is not in use.
I have tried various sizes bolts to simply fill it in with. However, not even LOWE's or Depot carries one large enough to fit it in the correct thread pattern.
Thanks.
Thanks.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
maybe look into getting a new oil pan with out the mystery hole in it and replaceing it .....
thats a pain in the *** but it might be your only resolution
Car: 1982 Firebird
Engine: 355 CID
Originally posted by Stekman
Welcome to TGO!
Welcome to TGO!
http://shbox.com/1/low_oil_sensor.jpg
Sometimes seeing helps. It appears they started making this in 1993 and used the same design through at least 1997.
Thanks for the help.
so now you just need to buy a sensor used or new and put it in the hole and your done then right ?
Pac J
May 17, 2020 10:44 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
