it's a lil smokey..
Old Sep 12, 2004 | 09:13 AM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
it's a lil smokey..
well my 84z has had a 350 change in it. 4bbl qjet. but i don't know what else has done with it and the prior owner didn't do any of it. so i'm sol. till i can get to the heads and block number. but when i start her up she give a nice puff of blue smoke. then thats done my friends who were following me one day. said it was smelling funny. and looked like it was smokeing just a tinny but. could my oil giudes be bad.?? any help or sugjestions will help. i added some lucas oil stabilizer. i've had good expirnce with them in the past. but thanks
Old Sep 12, 2004 | 10:34 AM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
well, if a car smokes blue smoke continuously even after warmed up, that indicates bad piston rings more than likely. If it only occured during initial startup, and then went away completely, then it would most likely be a valve seal(s) problem. Take out your spark plugs and inspect them for any oil coating. This will tell you if oil is entering your combustion chamber, whether it be leaking past the piston rings and up into the chamber, or leaking from the valve seals down into the combustion chamber. One question, how many miles is on this engine? Good luck.
Old Sep 12, 2004 | 01:06 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
i dunno how many miles are on it acctully. the odometer is broken. at 163xxx but i'm building a 383 stroker for it but i wanted to sell the 350 for a lol extra chas but if it's a piston ring i'm sol
Old Sep 12, 2004 | 01:27 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
ok i got the spark plug out. form my veachil calss in highschool i'm taking right now and waht i've learned form the chart of sprak plugs looks like thiers wear on the ground electorde. half the white is showing he other half is black and it's caoted in black every were else. so i forgot what this means any help woudl be nice
Old Sep 12, 2004 | 09:27 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Originally posted by ridecamro
veachil calss
I dearly hope thats not how your class spells "vehicle."
Blackish usually means oil deposits.
Old Sep 13, 2004 | 12:26 PM
ljnowell's Avatar
What is up with the rash of people lately who just cant spell anything? Is this how kids in school are nowadays? I think my 4 year old can spell better than some.
Old Sep 13, 2004 | 02:48 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
i'm sorry i'm jus tin a bit of a rush to get this done. i didn't check my spelling. and i'm not the best at it. i'm trying to work on it. but i gusse thats why i'm in "special" class for english. o well thanks for the help though.
Old Sep 13, 2004 | 03:33 PM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
Eye kin not spell ether becuze eye wint two publik skewls.
project89
Sep 24, 2015 06:38 AM
Racerx974
Sep 19, 2015 10:16 AM
383cam
Sep 9, 2015 06:01 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Stell1579
Jan 7, 2001 02:31 AM
