Valve seals, spring compressor?
Old Sep 15, 2004 | 12:20 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Been dreading this job for several months. Can't put it off any longer. Question is can I use the lever type compressor on the tuned port? This is the tool that looks like a nail puller. Will it clear the port runners when I put it on the stud? Is there a better tool for reasonable money? Thanks.
Old Sep 15, 2004 | 12:24 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i dont have tuned port, but i did mine with summits lever one.... and i didnt have to angle the lever toward the intake, so i assume it'll clear for the TPI.
btw, if you're using positive seals, do yourself a favor and buy the seal install tool. or make one on a lathe.
the two make the job easy.
gixxer92
Sep 1, 2015 04:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
