Intake power range, based on what engine size?
Old Sep 16, 2004 | 04:26 PM
Guss_B's Avatar
Car: '84 Z28 & '73 camaro LT
Engine: 1960 283, eaton m112 blower
Transmission: none at present, will be manual
Axle/Gears: 3.73:1 lsd
When a manifold has a power rating of, for instance, idle to 6500, what engine size is this based on? The amount of air a 350 pulls in at 6500 would see a 283 up to 8000rpm. My lil 283 sees peak power at 6800 (according to dd2000) and I really don't know what manifold would have the right range. I'm not looking for torque (I have a big block '73 camaro for that sort of thing, I want this engine to have totally different character) but I want a manifold that has the appropriate power range.
Any advice appriciated.
Old Sep 16, 2004 | 04:28 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
You really have to spec out the rest of the combo...along with what type of trans and gears...
Old Sep 16, 2004 | 05:11 PM
ljnowell's Avatar
Take all manufactures power range ratings with a grain of salt. They may say 3000-6000 or idle-7200 (I think is the weind excellerator). The problem is, they dont give any numbers. It could lose 20% under 3000 but still qualify to be rated that way, by thier standards. Try to match the intake to the engine, but realize that the manufacturers ratings are merely a generalization, or a guideline.
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I think its typically based on a 350.
Old Sep 16, 2004 | 05:19 PM
ljnowell's Avatar
Which is in fact another reason why the power ratings are off.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
knight72
Aug 10, 2015 09:32 PM
