fuel pump
Old Sep 17, 2004 | 05:38 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
fuel pump
My mechanical fuel pump is shot, time to go electeric.
Is a Holley red ok for my car?
where is the best place to intsall it?
what are the 2 lines that went to my old pump along the frame in the engine bay. they were rubber? Im guessing 1 is the inlet but the other I am unsure. I only see 1 inlet and outlet on the red pump, but my mechanical had 2 inlets?
I am assuming i will have to cut those steel lines when I install it?
Its for an 85 z28 with 305 4bbl
Old Sep 17, 2004 | 06:54 PM
ljnowell's Avatar
First things first, juggalo. Why do you want to go to an electric pump? The mechanical will feed more than enough fuel, and cost less than 15 dollars usually. It doesnt make much sense to spend the money to put an electric pump on your car, when you really dont need it. Buy the mechanical and spend the extra money on something that will actually make your car faster.
Old Sep 17, 2004 | 07:32 PM
2 dope's Avatar
Engine: 305 LG4
i can get the electric pump cheap, the pump, for a used one, mechanical, is approx $60 at the junkers. I can get electric cheaper than that
Old Sep 17, 2004 | 07:41 PM
ljnowell's Avatar
dude you are getting F U C K E D!!!!!!! I just bought a mechanical pump brand new at the parts store for 13.99. Where do you live? Do you have an autozone or Advanced Auto, Oreilys Auto, Carquest, anything? If anyone says anything more than 20 dollars for a mechanical pump for a SBC, they are screwing you royal.
Old Sep 17, 2004 | 07:43 PM
ljnowell's Avatar
I just checked, its 12.99 at autozone for your particular car. Never, ever, ever buy a used mechanical pump anyway.
Old Sep 17, 2004 | 07:51 PM
2 dope's Avatar
Engine: 305 LG4
I live in Canada. I will call Canadian Tire tomorrow and see how much a new one is. I can't see it being that cheap. I've seen some nice mechanical ones at summit for like $50, of course they flow more.
Well, if i go mechanical, i don't have to frig with the lines and such so thats kinda making me agree with you.
Old Sep 17, 2004 | 07:58 PM
ljnowell's Avatar
You wont have any problem getting it under 20 us dollars, however that converts. Also, a stock SBC mechanical pump will support a 400hp engine, easily. Too many people buy into the "high performance" garbage that magazines and parts catalogs talk.
Old Sep 17, 2004 | 08:07 PM
2 dope's Avatar
Engine: 305 LG4
i checked carpart.com
most $ was $100, cheapest was $10, wtf?
Old Sep 17, 2004 | 08:08 PM
ljnowell's Avatar
They probably carry everything from a stock replacement to the top of the line aftermarket.
Old Sep 18, 2004 | 07:05 PM
2 dope's Avatar
Engine: 305 LG4
I called Canadian Tire, they want $61 for it. I cant understand the price gap between the US and Canada.
Old Sep 18, 2004 | 08:44 PM
ljnowell's Avatar
Then I would order it from an american company, and have it shipped. You can do that, cant you?
Old Sep 18, 2004 | 09:13 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah in the us you can buy a fuel pump a hell of a lot cheaper than in canada from the sounds of it .......if you can have one shipped to your local from the us then i would from the sounds of it itll be cheaper in the long run .
Old Sep 18, 2004 | 09:31 PM
2 dope's Avatar
Engine: 305 LG4
I thought It'd be easy to do, Ive looked online, havent found any stores that will ship to Canada, if anyone finds any, please let me know.
Old Sep 18, 2004 | 09:34 PM
THEGENERAL's Avatar
ill do some checking for ya
Old Sep 20, 2004 | 07:48 PM
2 dope's Avatar
Engine: 305 LG4
well i finnaly got one, at NAPA, $29 Canadian, not too bad eh lol. Anyhow it was easy to put on, but i had to put a new fuel line on from the pump to the carb. That was a pita. The bending tool I have sucks so it took forever and some of the bends aren't perfect so I don't know if it'll be ok or if i should get a new line and start over?
Old Sep 21, 2004 | 07:14 PM
2 dope's Avatar
Engine: 305 LG4
do i need to seal the threads on the fuel line?
Old Sep 21, 2004 | 07:25 PM
THEGENERAL's Avatar
you shouldnt have to its a flared fitting but if it leaks you can always go to the autoparts store and get some thread tape rated for gasoline......
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
