what to use to clean parts?
Old Sep 17, 2004 | 08:42 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
finished breaking down my block today, so need to clean up the pistons and other stuff. need to know what's good stuff to use at home?
Old Sep 17, 2004 | 09:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Carb cleaner works pretty well on just about all metal parts.
Old Sep 17, 2004 | 09:32 PM
ljnowell's Avatar
Brake parts cleaner is a favorite for me, that and oven cleaner. It takes off all the baked on goodies.
Old Sep 17, 2004 | 09:34 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I always liked paint thinner and naphtha. Works nice and its cheap, although Im sure its also good for causing cancer.
Old Sep 18, 2004 | 07:16 AM
Car: '91 Z28
Axle/Gears: 323's
all good ideas - thanks. probably start working that today, but might wait til i find out if it's gotta be bored or not. i don't think so, but that's what i think, and so far i've ended up a lot deeper in to this than i planned... let's just say i was going to put new exhaust on it and work the heads. pulled the engine for leaks to fix and put a new cam in and the cam bearings are fried, so... it'll be getting new bearings and rings, too, but the block is going in to get tanked, too.
KAM
Old Sep 19, 2004 | 04:15 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Brake Cleaner all the way. Love that stuff. I probably went though at least 2 dozen cans on my motor pull/swap/install month or two back...
Old Sep 19, 2004 | 05:43 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
brake cleaner all the way, just keep it away from plastic, it will chew the **** outta it
Old Sep 19, 2004 | 09:04 PM
onebinky's Avatar
Laquer thinner for soaking, brake or carb cleaner for blasting
Old Sep 19, 2004 | 10:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Brake cleaner and oven cleaner here.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 5, 2015 11:57 PM
