finaly came across a motor
Old Sep 19, 2004 | 03:55 AM
Kaukasion's Avatar
Car: 84 z28
Engine: older 350, details unknown
Transmission: th350
Axle/Gears: factory limited slip
actualy im getting an entire 84 z28 with the ho motor (btw whats the diff between the lg4 and the ho package? is it just the quadrajunk carb?) but the 700r4 is out
so imma part that bitch out to a buddy that needs some body parts
get my windsheild and put the motor in my 86 ta
but no to the question
he claims that the motor smokes a lil bit cause the valve seals are bad
how much of a pain in the *** are they to change?
and about how much would it cost to do it
he is giving me the car for doing some tranny work on his amx javelin
replacing the front and rear seal
cant beat that deal
for a simple nutz and bolts job
oh and its got the mags of a 78 z28 on it that might look nice on the trans am kinda exicited imma finally get my baby runnin again
Old Sep 19, 2004 | 05:30 AM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
valve seals are cheap and fairly easy to change.just screw in air compresser line in the spark plug hole,put compressed air in the cylinder and get a valve sping commpresser and change 2 seals at a time.if the engine is out it will be even easier.
Old Sep 19, 2004 | 05:32 AM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
valve seals are cheap and fairly easy to change.just screw in air compresser line in the spark plug hole,put compressed air in the cylinder and get a valve sping commpresser and change 2 seals at a time.if the engine is out it will be even easier.but as many times as i hear peolpe say that there car smokes because the seals are bad it usally 90% of the time there engine is tired and wore out.
Old Sep 19, 2004 | 12:58 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Is it an L69 or LG4? , the L69 is the only HO in thirdgens.
Old Sep 20, 2004 | 01:55 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The HO is about 50hp better than the LG4. Its got higher compression (9.5 vs 8.5), bigger cam, more aggressive computer/carb tuning, dual snorkel air cleaner (vs dinky little snorkel air cleaner). The HO cars also had a better exhaust system.
Old Sep 27, 2004 | 02:45 PM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
im pretty sure its the L69
its got the ho badging everywhere and looks a bit diff then my ole lg4 did
Old Sep 27, 2004 | 02:50 PM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
so i should take the exhaust off too
its got a nice looking accel distributer and coil n stuff
im not a "mechanic" but ive swapped motors before in other lil cars
what exactly should be the main issues and main pain in the ***
the way im thinking about going about this is just unhook everything take out whatevers holding the tranny in out and driveshaft off then motor mounts and pull that whole thing out in one peice since imma keep the transmission too but its not going to go into the trans am imma keep my 700r4 cause i dont have the money to rebuild the five speed
while its out imma clean it up and tune it up just the basics plugs wires oil etc etc and prolly take a look @ the valve seals
i dunno just warn me about any major conflicts you forsee in the swap so i know what im going up agains when i hit it
Old Sep 27, 2004 | 02:52 PM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
also will the 700r4 be ok with hp and tourque increase?
its been just sittin for about 5 years too so i think i may change the front and rear seal along with the filter and fluid just incase
thanx for any help offered
Old Sep 27, 2004 | 02:57 PM
Air_Adam's Avatar
If its in good shape, it will be fine with an HO motor in front of it.
I would put a higher stall in it though if you put an HO engine in front of that trans. They like to rev alot more than any of the other 3rdgen engines do.
Old Sep 30, 2004 | 11:24 AM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
how big of a stall would help out?
Old Sep 30, 2004 | 01:07 PM
Air_Adam's Avatar
If its a stock L69, then i'd say around a 2400 stall would be good. I'm no expert on autos though, so if anyone wants to correct me...
Old Sep 30, 2004 | 01:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I'd say a 2400 would be nice, anythingin the mid 2000's will suffice. What gears are out back?
Old Sep 30, 2004 | 01:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: finaly came across a motor
https://www.thirdgen.org/techbb2/sho...hreadid=261488
If you really want help (from me, at least), you'll drop "quadrajunk" from your vocabulary.
Old Sep 30, 2004 | 05:04 PM
ljnowell's Avatar
While you're at it, since you are in springfield, when you throw away that "Quadrajunk" let me know, I will come and get it. I's only about 40 mi from you.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
