odd problem
Old Sep 20, 2004 | 03:15 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
odd problem
hello all, hopefully I can get some help with a new "little" problem that popped up. lately if my car has been idling for a little while (say five min or longer, example: waiting in the drive thru at mc dodads) I can drive away but when I stop my car dies. I'm not sure I can describe it better than that.
ohh and I would have searched but I have two reasons I didn't
1) I'm not sure what to search for
2) I'm off to work so I figure there will be a few responses by the time I'm off
thanks in advance for any ideas; by the way it happens regardless of how much gas is in the tank.
Old Sep 20, 2004 | 03:18 PM
sellmanb's Avatar
Car: '86 Berlinetta
does it stumble when it dies, or does it just cut off? this will help us determine either fuel delivery, or electrical problem.
Old Sep 20, 2004 | 03:48 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Man, I was born in Hibbing. Great town.
Auggie
Old Sep 20, 2004 | 08:07 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
it stumbles a little bit but for the most part it just dies. when I start it up again I have to give it some gas and basiclly brake stand to get moving.
please don't tell me its the fuel pump, anything but the fuel pump
yeah hibbings a good town, theres just nothing for jobs
Old Sep 21, 2004 | 06:38 AM
bobsroc's Avatar
Car: 1987 IROCZ
Have you checked anything? Fuel pressure, injectors, fuel pattern in throttle body, vacuum leaks? TPS/IAC? Timing?
Old Sep 21, 2004 | 12:57 PM
sellmanb's Avatar
Car: '86 Berlinetta
okay so i'm going to go off the notion of fuel starvation. I dont really know much about the fuel system, just remember... K.I.S.S. (Keep It Simple, Stupid -- and no, i'm not calling you stupid ). Start with the easy things like fuel filter, if you have a carb then there's a fuel filter inside of the carb as well. I'd do some tuning of your carb if it's not computer controlled.
Also, something that you can do is maybe you have too low of an idle and your carb doesnt shoot enough fuel in when braking, and with the loss of vacuum from the brake booster, it just kills off? I would this, it's free, easy and quick. Just disconnect your battery for 30 seconds - 1 minute. This will clear all the data from your ECM, starting you off brand new, this way your computer will have to re-learn (so to speak) your driving habits, and it will adjust the idle accordingly.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
