87 octane and a 300hp+ engine possible?
Old Sep 21, 2004 | 10:16 PM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
Transmission: 700-R4
just wondering..i want to go backwards of most people and build an engine that will run on 87 regular and still produce upwards of 300hp at the crank..
i might be limiting myself but on my lg4 the cr is 9.5:1 and i'm running 87, which is recommended in the manual.
would this be ok for a high hp car?
Old Sep 21, 2004 | 11:23 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you plan the engine right, then yes, you could have 300hp on 87 octane. Mostly you just have to keep the dynamic compression ratio in check and don't go overboard on the timing.
Old Sep 21, 2004 | 11:32 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
my cars got like 320 at the crank as it sits, can easily run on 87 but I put 89-91 for my own satisfaction and because the motor deserves it lol.
Old Sep 22, 2004 | 06:45 AM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
i think the compression ration is 10.3 or lower and it's safe to run 87. anything higher it's 89-92 or even higher. have fun
Old Sep 22, 2004 | 07:48 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Current issue of Hot Rod "Engines" 87 octane 406...490 HP
Old Sep 22, 2004 | 01:46 PM
Air_Adam's Avatar
10.3 on 87?? Thats REALLY pushing it...
Old Sep 22, 2004 | 08:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My old motor made 345HP Fly on 87 with 9:3:1 Comp
Old Sep 22, 2004 | 10:42 PM
Air_Adam's Avatar
My L69 (9.5:1) liked 87, but I wouldn't go any higher that that for CR unless you have a whopping huge cam.
bryan623
Mar 22, 2021 06:43 PM
Reddeath210
Oct 6, 2015 08:20 AM
jbd1969
Aug 17, 2015 07:06 PM
355tpipickup
Aug 13, 2015 07:35 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
