Differences between 86 LG4 and 87 TPI Motors????
Old May 12, 2001 | 10:07 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have an 86 carbed LG4 motor. I just bought a complete 87 TPI setup with 87 heads.
Are the blocks the same?
Is my 86 cam ok for the TPI setup?
What should I look out for when I do the swap?
I'll also need gaskets, what do I need so I can buy them before the TPI arrives?
Thanks,
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
View My Ride @ thirdgen.org
Old May 13, 2001 | 09:14 AM
Vader's Avatar
Zepher,
There is a reasonable outline of the differences between the years and models, engines, transmissions, and a host of other things in the Tech Articles.
Personally, I'd use both camshafts as paint stir sticks and get a decent one.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 13, 2001 | 04:27 PM
Slow Iroc's Avatar
Actually Vader, I found a great use for those cams...weapons! Sure, you ever bust somebody upside the head with the fuel pump lobe? Let me tell ya, they don't get back up right away! LOL.
Cam, pistons and heads are all dif. The compression I don't beleive (but could be wrong) won't be the same, because the LG4 pistons have a larger dish. Personally, I say sell that hunk of aluminum crap, build a 350, slap a 700 CFM double pumper on it, and laugh your *** off at the rest of us TPI morons. TPI sucks, go carb.
Old May 14, 2001 | 12:28 AM
Zepher's Avatar
ok, I'll check the tech articles.
Old May 14, 2001 | 01:51 AM
Bort62's Avatar
yeah, TPI sucks so Much, Ill Trade you My Carb and Intake For it.
Zepher, as far as bolting it all Together, It should work Just Fine. was the 87 a L98 or Lb9 ? Either way You should leave the LG4's heads intact, Unless you wanted to Do some port work, and swap the TPI strait onto em.
Now Im having Brainfade, And Cant reember if the LB9 used 416's or not, someoen with a little less history of drug use will ahve to answer that.
But, Yes everything will work.
If your gonna Go in that far, I would recommend swapping out the cam, as Vader pointed out, the Stock cam's In our cars are Quite useful For supporting your Mailbox, making a lamp, Or doing curls, and thats about It.
BTW< is that you in the pic? Tobad you don't live near me, hahaha.
www.amiahotthirdgendriverornot.com
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -&gt; My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
1992rs/ss
Jan 31, 2025 05:10 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
