Noob question about dist. wire coming loose and making my car die
Old Sep 23, 2004 | 11:51 PM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
Old Sep 24, 2004 | 12:09 AM
sellmanb's Avatar
Car: '86 Berlinetta
well i'll start out by saying that your car will be okay, it's just like turning off your car with the key.
now for the lesson... DUCT TAPE IS NOT A GOOD FIX FOR A CAR lol. It works, but that is the lamest look for a engine. i'm sure you could spread a little silicone over the clip and it would be fine then if you let it dry long enough (not too much incase you ever need to take the plug out)
just an idea.
Old Sep 24, 2004 | 12:36 AM
Cameron's Avatar
Car: 1985 Z28
Old Sep 24, 2004 | 02:03 AM
rezinn's Avatar
Actually the best fix would probably be zip tying the connector on. Better than replacing the connector unless you can do it without soldering new wires in or something. Same thing happened to me before and nothing bad came of it - just scary when it happens going up a freeway ramp at 80.
Old Sep 24, 2004 | 11:48 AM
Cameron's Avatar
Car: 1985 Z28
Old Sep 24, 2004 | 12:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like somebody used a 90° terminal on the coil wire, probably so it would "look" good; where they should have used a straight-in terminal.
Put the right end on the wire, instead of half-***-rigging it somehow.
Old Sep 24, 2004 | 02:10 PM
rezinn's Avatar
Er, sorry. I was tired last night and I wasn't reading I guess. I thought you meant a different wire that had part of the connector break off. Just replace the wire.
Old Sep 29, 2004 | 01:15 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
hey isnt duct tape rated at like 200 mph....LMAO..
thats what we always call it 200 mph speed tape......LOL
BRoss99
Aug 10, 2025 05:08 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
penguinpanda0
Aug 15, 2015 06:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
